Resultant and normal force of car on banked curve
The discussion revolves around a physics problem involving a car on a banked curve with a specific bank angle, radius, and mass. Participants are exploring concepts related to forces acting on the car, particularly the normal force and resultant force at the design speed, which is defined as the speed at which the car does not rely on friction to maintain its position on the banked curve.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the relationship between normal force and gravitational force, questioning the derivation of the equations involved. There is an exploration of the concept of design speed and its implications on the forces acting on the car. Some participants express confusion regarding the trigonometric functions involved and their application in the context of the problem.
The discussion is ongoing, with participants actively questioning and clarifying concepts related to the normal force and the design speed. Some have provided insights into the relationship between the forces and the geometry of the situation, while others are seeking further clarification on specific points, indicating a productive exchange of ideas without a clear consensus yet.
Participants note the complexity of deriving the equations related to the forces acting on the car and the assumptions that must be considered, such as the role of friction and the conditions under which the design speed is defined. There is also mention of the need for a free body diagram to better understand the forces at play.
diffusion
A car is on a banked curve of bank angle 18 deg, radius 70m. It's mass is 1020kg. Draw a free body force diagram approximately to scale, when the car is at the 'design speed'. What is meant by design speed? Find the resultant force and the normal force n.
ncos[tex]\theta[/tex] = mg
Design speed = Speed at which a car no longer relies on friction in order to keep from sliding down the bank.
To find the normal force, I think I am supposed to use the equation ncos[tex]\theta[/tex] = mg, or solving for n: n = mg / cos[tex]\theta[/tex]. Plugging in the values I get n = 1020kg x 9.81/ cos18, thus n = 10521 N. Is this correct? I'm poor with trig functions, so I'm not sure how or why cos relates to this equation. If someone could explain this that would be great, as I'm truly trying to understand this material.
Would the resultant force be = 0? If the car is at a constant "design speed", it is not accelerating, thus no net force.
The normal force 'Fn' is [tex]F_n=mg \cos{\theta}[/tex]. The concept here is of centripetal force. What force does the car experience when going around in a circle? Also what force is acting against it?
Oh, so even though the speed doesn't vary, there is still acceleration because v is changing direction.
Can you tell me where the cos comes from?
Actually, the normal force is not simply mgcos(theta). That is one component of it. Your solution, with n=mg/cos(theta) is correct.
Now, as for the derivation of this, it is somewhat more complicated. The first thing to understand is what is meant by the design speed. Do you understand that part?
Oh so we are shifting the coordinate system. Sorry for my erroneous remark.
The design speed is the speed of the car where it no longer relies on friction to keep it on the bank, yes? Should be constant as long as [tex]\theta[/tex] remains unchanged.
Well, in every physics problem I've ever seen, normal force is designed as normal to the surface. Your equation is correct for the component of normal force from gravity, but it is incorrect for the total normal force, which has another component as well.
Correct. Design speed is a function of [tex]\theta[/tex], as well as of corner radius (which is a constant for this problem)
From that deduction, what can you say about the relationship between V, R and theta?
Well, I know that tan[tex]\theta[/tex] = v^2 / rg, I just don't know why or where the tan comes from. Not sure if this is what you are referring to.
That is what I am referring to, but you do have to understand where the equation comes from. What are the two main forces that occur in this problem? How are they related? Once you understand this relationship, the tangent becomes obvious. If you can't seem to get it, draw a free body diagram of the car.
Note: Also, for this work, think of trig functions as the triangle side definitions. I.E., think of sin(x) as the opposite side of the right triangle divided by the hypotenuse.
I think I see what you're saying. Forgive me for my difficulty, I'm in a college physics course which assumes experience with high school physics; I have none. :(
So I drew the following two diagrams. Radius was easy to locate, direction of velocity would be tangent to the curve where the car is located, so there's my opposite and adjacent. Seems to make sense.
What confuses me now is where does the g come from in the equation tan[tex]\theta[/tex] = v^2 / rg. If I didn't already know the equation, by looking at the diagrams here I would have put: tan[tex]\theta[/tex] = v / r
Derive the equation by considering vertical and horizontal force components. Write Newton's 2nd law for each direction, then combine the two equations.
You have the right idea, but are applying it to the wrong triangle.
As Doc Al said, consider vertical (which you already have, with the mg arrow in your diagram) and horizontal forces acting on the car.
  • · Replies 41 ·
  • · Replies 20 ·
