Thread Closed
calculating the magnitude of the force on an electron
Share Thread Thread Tools
Mar22-09, 09:33 PM   #1
an electron travels at a speed of 2.0X10^4 m/s threw a uniform magnetic feild whose magnitude is 1.2x10^4 T. what is the magitude of of the force on the electron if its velocity vector and magnetic vector are
a)parralel
b)45degrees
c)parralel
2. Relevant equations
Fmax=QVB
F=QVSintheta
3. The attempt at a solution
for a i got .0012
b i got 16.47N
c i got 0
i think i am using the wrong equations
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Mar22-09, 11:22 PM   #2
Recognitions:
Homework Helper Homework Help
well using the right hand rule, which says that the current,force and magnetic field are at 90 degrees to each other, you'd see that if the velocity direction is parallel to the magnetic field you have no force.
Use th equation F=BQvsin[itex]\theta[/itex] to get the force for part b
Thread Closed
Thread Tools
Similar Threads for: calculating the magnitude of the force on an electron
Thread Forum Replies
Calculating absolute magnitude and apparent magnitude Advanced Physics Homework 1
Calculating the magnitude of the net force bewteen charges Introductory Physics Homework 5
Magnitude and direction of the force on the electron Advanced Physics Homework 1
Electron Sphere and Magnitude Introductory Physics Homework 7
Calculating magnitude and direction Introductory Physics Homework 0
