Lightweight and Very Strong Material
  • Thread starter Thread starter Seraph042
    Material
The discussion revolves around selecting a strong and lightweight material for a theoretical project in a Mechanics of Materials class. Participants explore various material options and considerations related to the project's requirements, including structural design and load-bearing capabilities.
  • Exploratory, Technical explanation, Conceptual clarification, Homework-related
  • One participant suggests materials like diamond, silicon, and carbon fiber for their strength-to-weight ratios.
  • Another participant prompts consideration of stress states and deflection in the bar under load, questioning what factors determine the beam's load-carrying capacity.
  • A different participant asks about the criteria for material selection, seeking clarity on the basis for choosing a material.
  • One participant mentions that the project is simple, focusing only on axial tensile force and applied torque, and expresses interest in Spectra fibers but needs its shear modulus for further analysis.
Participants have not reached a consensus on the best material or selection criteria, and multiple viewpoints regarding material options and design considerations remain present.
Participants have not defined specific assumptions or limitations regarding material properties or project constraints, and there is an absence of resolved mathematical steps related to the analysis of materials.
Students and professionals interested in material selection for engineering projects, particularly in mechanics and structural design.
Seraph042
For my Mechanics of Materials class, we have a project where we are given a shaft three points, with specified lengths in between each point, a specified load at one endpoint, and an applied torque at the middle point.
We get to decide the material and its structure (constantly changing cross-section, prismatic bar, two straight bars) etc.
This project is purely theoretical and no actual manufacturing will go into it, and as such no cost is an issue
I am looking for a strong and lightweight material to use for this project, cost is no concern. Anyone have any ideas ?
Right now I'm thinking something like:
Diamond
Silicon
Carbon Fiber
From your Mechanics of Materials lectures, how have you learned to define the stress state in the bar under the application of a point load? What determines the deflection of the beam at that centre point? What will be the limiting factor in the beam's ability to carry a load? As in where will it break and what state is that region in? Thinking about these things will help you decide on material suitability as well as cross sectional area.
What are you going to use as your basis for your selection? In other words, what criteria are you going to be using to select the material?
This is our first design project and as such is very simple. We only have to consider an axial tensile force and an applied torque. There will be no deflection considered, and it is purely design. Right now I'm looking for a lightweight strong material and have found some Spectra fibers, but am in need of its shear modulus to continue
11K
