| Thread Closed |
Commenting out a WRITE statement in FORTRAN 95 causes changes in non-related outputs |
Share Thread | Thread Tools |
| Mar23-09, 02:03 AM | #1 |
I have a stochastic dynamic program with markov process written in FORTRAN, below. If you comment out the write statement that says "uh, THIS SHOULD MAKE NO DIFFERENCE" and/or some of the other write statements that are just text, no variables being written, you will see a difference in the final array output as compared to when you do not comment any out.
experiment with commenting some of the write statements out/bringing them back in and look at the output array. can anyone explain this? it happens on more than one computer. PROGRAM HW4A IMPLICIT NONE REAL :: S !current storage REAL :: LI !previous inflow REAL :: R !planned current release REAL :: P !penalty based on planned current release REAL :: oops !cost of releasing less than planned release REAL :: f !future costs sum REAL :: OFP !optimum future costs REAL :: OCR !optimum current release INTEGER :: t,st,lin,cin,fst,re !counter indexes for loops and array addresses !stage, storage, last inflow, future storage, release !row is current inflow, column is current storage REAL, DIMENSION(5,0:7) :: Of !best future costs for storage and inflow REAL, DIMENSION(5,0:7) :: OR !best release for storage and inflow REAL, DIMENSION(5) :: PIC !probabilities of next inflows t=20 ! WRITE (*,*)"Number of Stages to run?" ! READ(*,*)t ! WRITE (*,*)" Based on",t,"year SDP" DO !for each t st=0 !reset current storage DO !for each S lin=1 !reset previous inflow DO !for each I re=0 !reset current release LI=lin*10. OFP=9999999 !reset optimum future cost CALL INFLOWPROB(LI,PIC) DO !for each R R=re*10. CALL PENALTY (R,P) f=0 !reset future costs accumulator cin=1 !reset current inflow DO !for each current inflow fst=st-re+cin IF(fst<0)THEN oops=5000 fst=0 ELSE oops=0 END IF IF(fst>7)fst=7 f=f+PIC(cin)*(Of(cin,fst)+oops) IF(cin==5)EXIT cin=cin+1 END DO IF(OFP>P+f)THEN OFP=P+f OCR=R END IF IF(re==5)EXIT re=re+1 END DO Of(lin,st)=OFP OR(lin,st)=OCR ! WRITE(*,*)Of(3,3) IF(lin==5)EXIT lin=lin+1 END DO IF(st==7)EXIT st=st+1 END DO ! WRITE (*,*)" ____________STORAGE____________" ! WRITE (*,*)" 0 10 20 30 40 50 60 70" ! WRITE (*,*)" ________________________________" ! WRITE (*,*)"I 10:",NINT(Of(1,:)) ! WRITE (*,*)"N 20:",NINT(Of(2,:)) ! WRITE (*,*)"F 30:",NINT(Of(3,:)) ! WRITE (*,*)"L 40:",NINT(Of(4,:)) ! WRITE (*,*)"O 50:",NINT(Of(5,:)) ! WRITE(*,100)Of !100 FORMAT(1X,5(8F10.0,/),/) IF(t==1)EXIT t=t-1 END DO write(*,*)"uh, THIS SHOULD MAKE NO DIFFERENCE!!!" WRITE (*,*)" Advised Releases based on" WRITE (*,*)" Last Season Inflow and Current Storage" WRITE (*,*)" ____________STORAGE____________" WRITE (*,*)" 0 10 20 30 40 50 60 70" WRITE (*,*)" ________________________________" WRITE (*,*)"I 10:",OR(1,:) WRITE (*,*)"N 20:",OR(2,:) WRITE (*,*)"F 30:",OR(3,:) WRITE (*,*)"L 40:",OR(4,:) WRITE (*,*)"O 50:",OR(5,:) END PROGRAM HW4A !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! SUBROUTINE PENALTY(Q,P) REAL, INTENT(IN) :: Q REAL, INTENT(OUT) :: P REAL :: a = 10 REAL :: b = 2 REAL :: T = 30 ! penalty function IF(Q<T)THEN P = a*T*(EXP(b*(T-Q)/T)-1) ELSE P=0 END IF END SUBROUTINE PENALTY !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! SUBROUTINE INFLOWPROB(LI,PIC) REAL, INTENT(IN) :: LI !previous inflow REAL, DIMENSION(5), INTENT(OUT) :: PIC !current inflow probability IF(LI == 10)THEN PIC(1) = 0.8 PIC(2) = 0.1 PIC(3) = 0.1 PIC(4) = 0 PIC(5) = 0 ELSE IF(LI == 20)THEN PIC(1)= 0.3 PIC(2) = 0.3 PIC(3) = 0.3 PIC(4) = 0.1 PIC(5) = 0 ELSE IF(LI == 30)THEN PIC(1) = 0.1 PIC(2) = 0.3 PIC(3) = 0.3 PIC(4) = 0.2 PIC(5) = 0.1 ELSE IF(LI == 40)THEN PIC(1) = 0.1 PIC(2) = 0.3 PIC(3) = 0.3 PIC(4) = 0.2 PIC(5) = 0.1 ELSE IF(LI == 50)THEN PIC(1) = 0.1 PIC(2) = 0.2 PIC(3) = 0.3 PIC(4) = 0.3 PIC(5) = 0.1 END IF END SUBROUTINE INFLOWPROB |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Mar23-09, 11:10 AM | #2 |
Recognitions:
Hi kingfisher,
One line that I noticed was this one: Code:
f=f+PIC(cin)*(Of(cin,fst)+oops) I don't know how that would give the behavior you are talking about though. Can you give the different outputs that you are getting when the write statement is commented out and active? Also, what compiler are you using? |
| Mar23-09, 05:23 PM | #3 |
YOU ARE GREAT, AND I THANK YOU
initializing the array was the solution |
| Mar23-09, 10:45 PM | #4 |
Recognitions:
Glad to help! That was an interesting bug; I actually got identical outputs with my compiler whether the write statement was commented out or not, so I could not reproduce the behavior.
But I'm guessing that your compiler chose a different memory location for the variable array Of(,) based on whether the write line was there or not, which caused different "random" values to be used. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Commenting out a WRITE statement in FORTRAN 95 causes changes in non-related outputs
| Fortran write (or print). How to controll "new line" or not | Programming & Comp Sci | 7 | ||
| Need outputs for fortran 77 programs | Programming & Comp Sci | 0 | ||
| Fortran 90 very basic question : else if statement | Programming & Comp Sci | 6 | ||
| Help me to write fortran code | Programming & Comp Sci | 1 | ||
| Help! need to write fortran program | Programming & Comp Sci | 8 | ||
