Maximum Stress on a wheel in motion
To calculate the maximum stress on a wheel traveling at 180 m/s and weighing 2000 kg upon impact with a solid object, one must determine the force exerted during the collision. The relevant equation for stress is stress = force/area, but additional parameters such as the material's yield strength and modulus of elasticity (E) are crucial for accurate calculations. The discussion highlights the need for a formula to estimate the maximum force transmitted to the wheel during impact. Understanding these factors will aid in designing a wheel that can withstand the calculated stress without exceeding its yield strength. Accurate calculations are essential for ensuring the wheel's safety and performance under extreme conditions.
Davieslad
I have a vehicle traveling at 180 ms^-1, weighing 2000kg.
I need to calculate the maximum stress that the wheel is likely to sustain if it hits a solid, immovable object at the above speed, so that i can successfully design a wheel which won't go beyond its yield strength.
Does anyone know of any formula to calculate the maximum force transmitted to the wheel
stress = force/area
Im not really sure where to start with the maximum stress.
Any help much appreciated
Cheers
Ed
I would think you'd need to at least know the modulus E of the material to find the max allowable stress?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
