Voyager: How Did They Navigate Unknown Worlds?
  • Context: Undergrad
  • Thread starter Thread starter one_raven
    Flying Voyager
The discussion revolves around the navigation strategies employed by the Voyager mission as it traveled through the outer solar system. Participants explore the challenges and uncertainties faced by mission planners, particularly regarding gravitational assists, trajectory adjustments, and the limited knowledge of planetary environments at the time of planning.
  • One participant expresses confusion about how the Voyager mission could plan precise trajectories using gravity assists without detailed geological information about the planets.
  • Another participant asserts that detailed geological information is not necessary for computing celestial mechanics, as orbital data and total mass are sufficient.
  • A later reply suggests that the gravitational force exerted by Saturn was determined by observing its effects on known satellites, which provided the necessary mass information.
  • Concerns are raised about the risk of collision with undiscovered moons and debris, with one participant noting that Saturn's vicinity is not very crowded, thus minimizing the risk.
  • Participants discuss how Voyager was able to make trajectory adjustments mid-course, with one suggesting that some fuel reserves were available for small corrections.
  • Another participant references a press release to support the claim that Voyager had thrusters and fuel for course corrections.
  • One participant highlights the potential dangers posed by Jupiter's rings, which were not known until after Voyager's flyby, and discusses the implications of these surprises on mission planning.
  • It is noted that the trajectories of the Voyagers allowed for more accurate estimates of the masses and orbits of planetary moons, which were refined through close flybys.
Participants do not reach a consensus on the adequacy of the information available for planning the Voyager trajectories, with some asserting that sufficient data existed while others question the assumptions made. The discussion remains unresolved regarding the extent of risks and surprises encountered during the mission.
There are limitations regarding the assumptions made about planetary environments and the accuracy of pre-mission data, as well as unresolved details about the specific maneuvers and adjustments made during the mission.
one_raven
Something struck me as confusing, and I'm sure it's just that I don't have enough information yet.
The Voyager mission found MANY surprises in the planets they studied.
In fact, it seems they were wrong about more than they were right about, not to mention all they found out that they simply did not consider before.
What is confusing to me is that they planned this intricate and precise trajectory employing gravity assist while knowing so little about the planets, including geological makeup. Hell, they STILL don't know how deep the clouds are on Jupiter and know nothing at all about the central mass (if there even IS one).
Lacking all this information, how did they know how far and fast the planets would "sling" the Voyagers?
The measurements had to be extremely precise to get it right, where did they get the numbers?
How did they know how much gravitational force Saturn would exert on the crafts?
How did they avoid debris and moons that were so far that they did not even know they existed at the time?
With all fuel burned up early in the voyage, how did they change the trajectory mid-course like they did to pass over the north pole of Neptune?
:confused:
Astronomy news on Phys.org
The Voyager Enigma
All very good questions.
However, I doubt you will receive many satisfactory answers...
You do not need detailed geological information to compute celestial mechanics. The orbital data and total mass gives all you need. This information has been well known for generations.
By observing how Saturn effected the satellites we already knew it had. This told us Saturn's mass. (which is all we needed to know)
Even with the yet undiscovered moons, Saturn's neighborhood is not very crowded. The chances of hitting anything significant, while not zero, were extremely small.
:confused:
I would have to say that they hadn't used up all their fuel and they had some reserve to make small course adjustments.
On the course change issue, see the following press release.
http://www.jpl.nasa.gov/releases/80s/release_1986_1085.html
Note that Voyager had thrusters and fuel to allow it to make course corrections.
Thanks for all the information.
It all makes sense now.
Oh shut up. Like you really know anythink. All the answers were great ones. Go back to your conspiracy theories.
There were some surprises that *could* have made a difference. For example, the rings of Jupiter. Like all planetary rings, they are composed of small particles; if anyone of these had collided with Voyager (or the earlier Pioneers, or Galileo, ...) some damage would have been done, possibly fatal (to the spacecraft ) damage. These rings weren't discovered until Voyager 1 took some deep pictures (I don't recall whether this was before it reached the Jovian system or as it was leaving); Voyager 2 was reprogrammed to do more detailed investigation (and planetary rings became a much more active topic, with all kinds of discoveries subsequently, for Saturn, Uranus, and Neptune).
Fortunately, the Voyagers didn't go anywhere near the Jovian rings (we already knew that the radiation environment that close in would have been fatal to the spacecraft ). However, there was once a plan to send a craft (one of the Voyagers?) through the Cassini division in the Saturn ring system - the thought was it was truly a clear gap. Fortunately, this is not how the trip ended up, because the Voyagers showed that the Cassini division isn't empty at all!
The Voyagers' trajectories enabled us to make much more accurate estimates of the masses (and orbits) of the planetary moons which they passed near; the closer they passed, the more accurate the estimates. Conversely, before the fly-bys, inaccuracies in the estimates meant the possibility of collision; it was partly for this reason that the only extremely close flyby (of Triton) was the last one done; it mattered much less by then if there was a collision! (similar story for Voyager 1 and Titan).
  • · Replies 24 ·
  • · Replies 86 ·
9K
  • · Replies 22 ·
