| Thread Closed |
non-integer roots of complex numbers |
Share Thread | Thread Tools |
| Mar24-09, 11:55 AM | #1 |
[tex]\sqrt[n]{Z}[/tex] has exactly n distinct value for integer n. What can you say about non-integer n's ? 2. Relevant equations [tex]\sqrt[n]{Z}={|Z|}^{1/n}.(cos((\theta+2k\pi)/n)+isin((\theta+2k\pi)/n)[/tex] 3. The attempt at a solution I used Euler's formula to see clearly what the roots are if n is integer. As it is told i find [tex]\sqrt[n]{Z}[/tex] has n roots. But what if n is non-integer? I've been told that if n is non-integer there will be infinite solution. How could it be? |
| Mar24-09, 12:47 PM | #2 |
Recognitions:
That's not quite true. If you can see what the roots are when n is an integer then you can probably figure out what the roots are when n is rational and there's only a finite number. The case where n is irrational is where you have an infinite number of solutions. Can you show that?
| Mar24-09, 03:28 PM | #3 |
If i take n, for instance 2.3 there will be several solution because at a certain k value i will notice that i've found the same root before.
if i take n=2.34 there'll be more solution because cosine or sine of it will have different values from previous ones..and the number of solutions increase with the increase in number of fractions. If I think an irrotational number is infinitely long there will be infinitely different solutions. Is that the case or just a piece of nonsense i make up? |
| Mar24-09, 04:10 PM | #4 |
Recognitions:
That's roughly true. Two roots corresponding to the integers k1 and k2 are going to be the same if 2*pi*k1/n and 2*pi*k2/n differ by a multiple of 2*pi. Can you show if n is irrational then that can never happen?
| Mar24-09, 04:39 PM | #5 |
c is an integer
[tex](2{\pi}k1 - 2{\pi}k2)/n = c2\pi[/tex] [tex]k1 - k2 = cn[/tex] hence k1 and k2 is integer, n must be integer too to have same roots. that means if n is an irrational number this equation cannot be satisfied namely all roots we can find are different so we can say there are infinitely many distinct roots, is this correct? |
| Mar24-09, 04:44 PM | #6 |
Recognitions:
Exactly right. That would mean (k1-k2)/c=n. The left side is rational, the right side isn't. The roots are all distinct.
| Thread Closed |
| Thread Tools | |
Similar Threads for: non-integer roots of complex numbers
| roots of a equation with complex numbers | Calculus & Beyond Homework | 4 | ||
| Roots of complex numbers | Calculus & Beyond Homework | 1 | ||
| AHH! complex numbers how to find roots for this equation? | Calculus & Beyond Homework | 5 | ||
| Roots and complex numbers | General Math | 2 | ||
| Roots of Complex Numbers, Help! | Introductory Physics Homework | 8 | ||
