How to Find the Volume of a Solid Bounded by a Cylinder and Planes?
  • Thread starter Thread starter rhyno89
    Integrals Volume
The volume of the solid bounded by the cylinder defined by y = |x| and the planes y = 2 and y = 8, under the surface z = 1/(x^2 + y^2), can be computed using double integration. The correct setup involves integrating over a trapezoidal region, where the integral can be simplified by exploiting symmetry. The recommended integral format is 2∫ from y = 2 to 8 of ∫ from x = 0 to y of (1/(x^2 + y^2)) dx dy, which accounts for the symmetry of the function.
  • Understanding of double integrals in calculus
  • Familiarity with the concept of cylindrical coordinates
  • Knowledge of the properties of symmetry in mathematical functions
  • Ability to interpret and visualize geometric regions in the xy-plane
  • Study the application of double integrals in volume calculations
  • Learn about cylindrical coordinates and their use in integration
  • Explore the concept of symmetry in mathematical functions and its implications for integration
  • Practice setting up integrals for various geometric shapes and boundaries
Students and educators in calculus, mathematicians focusing on integration techniques, and anyone involved in solving volume problems related to solid geometry.
rhyno89
find the volume of the solid that lies below the graph of z = 1/(x^2 + y^2) and that is bounded laterally by the cylinder set y =|x| and the planes y = 2 and y = 8
well i kno that the z equals equation is what i will be integrating, so i was wondering the significance of the y = planes. If done on an xy plane then the y equals is the bounds and I am integrating the region b/w y = 2 and 8 in regards to the y =|x|
What i set up was the integral from 2 to 8 of the integral of -y to y of (1/x^2 + y^2)dydx
Am i on the right track?
Close, but be careful. When you're integrating with respect to y, you also have y in the bounds. You have an expression for how y varies, so use that instead.
The region over which you're integrating is a trapezoid, where the parallel sides are the lines y = 2 and y = 8. The nonparallel sides come from y = |x|. Because the graph of z = 1/(x^2 + y^2) is symmetric with respect to both the x- and y-axis, you can make your integral a little simpler by integrating over half the region and multiplying your result by 2.
In other words, one possibility for your integral is this:
[tex] 2\int_{y = 2}^8 \int_{x = 0}^y <your function> dx dy[/tex]
You could set it up so that the order of integration is reversed, but that would make things more complicated.
  • · Replies 27 ·
