Register to reply
Getting a PhD while working? Is it doable?
by windsupernova
Tags: doable, working
Share this thread:
windsupernova
#1
Mar24-09, 10:50 PM
P: 29
Hi I want to get a PhD eventually. My plan is to finish my undergrad and then start working to gather money and then get a Phd. Is getting a PhD a full time thing?
Phys.Org News Partner Science news on Phys.org
New type of solar concentrator desn't block the view
Researchers demonstrate ultra low-field nuclear magnetic resonance using Earth's magnetic field
Asian inventions dominate energy storage systems
j93
#2
Mar25-09, 02:24 AM
P: 286
Are you doing a science PhD because for science PhD you will usually get a stipend to live on.
Choppy
#3
Mar25-09, 08:17 AM
Sci Advisor
P: 2,706
Quote Quote by windsupernova View Post
Basically - yes. It's a full time job. I worked part-time while doing my Ph.D. (on top of TA assignments) and while that was possible, it set me back. I graduated well after others who started at the same time as I did and who did not have part-time jobs.
Working full time is possible, but it will take even longer for you to finish.
fasterthanjoao
#4
Mar25-09, 10:27 AM
P: 731
Which country are you from?
In the UK a full-time PhD takes around 3-4 years, and in science are generally funded for around Ģ13k though if students in other circumstances or e.g. with exceptional grades can apply for extra funding in the form of scholarships from other sources. On top of this, you get a small amount of money for tutoring and attending lab sessions etc.
It's also possible to do a part-time PhD where one may have a 'job' for 3 days a week and PhD for the other 2 (then weekend for 2!) however this will mean completion can take up to 6+ years and it should also be noted that part-time PhD's generally require self-funding so you'd have to pay fees from the money you earn with your day job.
Maxwell
#5
Mar25-09, 11:44 AM
P: 531
Or if you work for a company that reimburses tuition + course fees, you'll essentially be attending for free. It will just be a major time investment.
TMFKAN64
#6
Mar25-09, 12:13 PM
P: 1,084
I have two data points.
Way back when I was a CS grad student, one of the other students worked for a company that was paying his way through the Ph.D. program. However, he was a full-time student, and I think he only worked for them during the summers. He also pretty much set the land speed record for graduating.
Secondly, my brother-in-law is currently getting an engineering Ph.D. while working for the government. He is still expected to work about half-time while he completes his studies. Time for qualifiers and the like come from his PTO.
So, it's possible, but it seems to me that the pressures are considerably greater and you have much less personal time than you would otherwise.
windsupernova
#7
Mar31-09, 07:21 PM
P: 29
So basically If I want to get a PhD, I may as well start ASAP after I finish undergrad right?
Mmm, donīt know if I will be able to afford it anyways. Time to do some more scolarship hunting
TMFKAN64
#8
Apr1-09, 12:04 AM
P: 1,084
That's the usual path. Others are possible, but I think it's easiest if you just follow the crowd.
As for affording it... as j93 mentioned, most Ph.D. programs in the sciences provide a stipend in exchange for some research or teaching duties... money shouldn't really be an issue other than it is typically a *small* stipend...
Register to reply
Related Discussions
Working out a value for H? Introductory Physics Homework 3
Just Tell Me If Its Doable (Vectors) Introductory Physics Homework 4
Who's Working General Discussion 2
DVD-R/RW not working? Computers 3
PC not working? Computing & Technology 3
