What is Pendellosung? | Get Answers Now
  • Context: Graduate
  • Thread starter Thread starter kaise_sose
The discussion centers around the concept of "Pendellosung" in the context of Transmission Electron Microscopy (TEM) and its potential relation to Laue conditions and diffraction patterns. Participants explore its meaning and implications in experimental physics, particularly in relation to crystal structures and diffraction phenomena.
  • One participant inquires about the meaning of Pendellosung, suggesting it might relate to crystal defects or Laue conditions.
  • Another participant clarifies that "Pendellosung" translates to "pendulum solution" in German, but does not elaborate on its physical significance.
  • A participant speculates that Pendellosung may be connected to higher intensity diffraction rings observed in TEM, particularly in relation to higher order Laue zones.
  • Another participant recalls Pendellosung fringes from X-ray diffraction studies, suggesting a possible connection to spherical waves and structure factors in wedge-shaped single crystals, and posits that similar principles may apply to TEM.
Participants express uncertainty about the precise meaning and implications of Pendellosung, with multiple competing views on its relationship to Laue diffraction and TEM. No consensus is reached regarding its definition or application.
Participants acknowledge gaps in their understanding of the physics behind Pendellosung, with some relying on linguistic clarification rather than technical knowledge. The discussion reflects varying levels of familiarity with the topic.
This discussion may be of interest to students and researchers in physics, particularly those focusing on crystallography, electron microscopy, and diffraction techniques.
kaise_sose
Hi All,
Doing an experiment at uni on TEM,
I need to know what Pendellosung is.
I suspect either it is some sort of crystal defect or
it is related to Laue condition and Ewald sphere, but these are only guesses.
I really don't know.
Please help
Thanks
Can't tell you what it means physically, but the word "Pendellösung" is German and means "pendulum solution"
Does that help?
well if that is the case then I suppose that my first thought that it was related to the Ewald sphere is correct.?
Is it all related to the rings of higher intensity diffraction from higher order Laue zones, which you observe on TEM when looking at diffraction pattern.
From your post I was not sure wheather you knew the answer (and were nudging me in the correct direction) or you were yourself guessing.
I don't know a thing about the physics here, ONLY the meaning of the German word.
I only hoped that by clarifying the meaning of the WORD, you would know the meaning of the PHYSICS
That's cool
still stuck.
Damn physics assignments
I recall something about Pendellosung fringes when I was doing a course in X-ray diffraction. I think you can use spherical waves to determine the structure factor in a wedge shaped single crystal.
Perhaps the same idea works for TEM too. So I too would guess that it is related to Laue diffraction.
