Lorentz Force and Coulomb Force
The discussion focuses on calculating the forces between two identical point charges using both the Lorentz force and the Coulomb force. The Lorentz force equation, F = q(e + (U X B)/C), is applied to determine the interaction in a moving frame, while the Coulomb force equation, F = ke(q1q2/r^2), is transformed from the particle's rest frame to the moving frame S. Participants express uncertainty about incorporating the distance r and transforming the electric and magnetic fields appropriately, referencing specific educational resources for clarification.
  • Understanding of Lorentz force and its components
  • Familiarity with Coulomb's law and its applications
  • Knowledge of electromagnetic field transformations
  • Basic grasp of relativistic effects and the Lorentz factor
  • Study the derivation of the Lorentz force in detail
  • Explore electromagnetic field transformations using covariant and contravariant forms
  • Learn about the implications of relativistic speeds on electric and magnetic fields
  • Review educational resources on electromagnetic theory, particularly the referenced slides from George Mason University
Students and educators in physics, particularly those focusing on electromagnetism and relativistic mechanics, will benefit from this discussion.
SpaceTrekkie
In frame S, two identical point charges q move abreast along lines parallel to the x-axis, a distance r apart and with speed v. Determine the force in S that each exerts on the other:
a) using the lorentz force in conjunction with the field of a moving charged particle
b) by transforming the Coulomb force from the particle's rest frame to the frame S
F = ke(q1q2/r^2)
For a) I am not sure how to incorporate r into the equation (i assume that u and v are the same for this problem...meaning I can use v in the equation instead of u. I think it has to do with the field of a moving charged particle, but I can't see how that relates in a way that I can use.
For b) I am not sure how that could be transformed. I know how to transform E and B using the covarient and Contravarient forms. And I don't see how the speed would fit into that...does it go back to the basic lorentz factor, that has v in it.
okay I think I figured out the second one. It is a lot simpler than I was thinking. But 1, I still have no idea. My teacher's hint was use www.physics.gmu.edu/~joe/PHYS428[/URL] topic 6 slide 15. But I do not see how that would work out...
  • · Replies 55 ·
  • · Replies 16 ·
