Converting 25 Degrees to Radians: A Puzzling Question
  • Thread starter Thread starter zillea
    Degrees Radians
To convert 25 degrees to radians, multiply by the factor of \(\frac{\pi}{180}\). This method is based on the relationship that 360 degrees equals \(2\pi\) radians. The correct conversion ensures that degrees are in the denominator to cancel out, leading to the formula: radians = degrees × \(\frac{\pi}{180}\). A common mistake is swapping the numerator and denominator, which results in an incorrect answer.
  • Understanding of basic trigonometric concepts
  • Familiarity with radians and degrees as angular measurements
  • Knowledge of mathematical operations involving fractions
  • Experience with tools like slide rules for manual calculations
  • Learn about the unit circle and its applications in trigonometry
  • Explore the use of slide rules for various mathematical conversions
  • Study the relationship between degrees and radians in more complex trigonometric functions
  • Practice converting between degrees and radians using different angles
Students, educators, and anyone involved in mathematics or physics who needs to understand angular conversions and trigonometric principles.
zillea
this should be a simple question, but I am just not getting the right answer. I need to change 25 degrees to radians. I know, that 360 degrees = 2pi radians, but I am not getting the right answer.
thanks for the help
multiply 25 degrees by [tex]\frac {\pi}{180}[/tex].
Just look at the units to remember how to do this. (number in radians and degrees are technically unitless, but use radians and degrees as the units)
Just to expand ...
You were on the right track. The only possible way I can see you getting the wrong answer is if you got your denominator and numerator swapped.
If you want to convert from degrees to radians, you want to get rid of the degrees. That means the degrees has to be in the denominator so it cancels out.
If you want to convert from degrees to radians, you want to get rid of the radians. That means the radians has to be in the denominator.
Since [tex]\frac{2\pi}{360} = \frac{\pi}{180}[/tex]
and [tex]\frac{360}{2\pi} = \frac{180}{\pi}[/tex]
Most people just multiply degrees by [tex]\frac{\pi}{180}[/tex]
or radians by [tex]\frac{180}{\pi}[/tex]
If you happen to have a good slide rule, it's even easier. Set the cursor over the number of degrees on the D scale, and move the slide until the r mark on the C scale is under the hairline. Look below the C index and you have your number of radians. (This is basically the same as dividing the number of degrees by 57.2957795, which happens to equal 180/pi).
