Physics Confusion: The Ball's Trajectory in an Upward Throw Explained
  • Thread starter Thread starter omgwtf
    Confusing
The discussion revolves around the motion of a ball thrown upwards with an initial speed of 29.4 m/s, considering the effects of gravity with an acceleration of -9.8 m/s². Participants explore the implications of the ball's trajectory over a time frame of 4 seconds, questioning the relevance of calculations beyond the point where the ball is said to stop after 3 seconds.
  • Participants discuss the initial conditions of the problem, questioning the clarity of the original poster's queries regarding the ball's velocity after 4 seconds and the interpretation of stopping time. They also examine the relationship between initial speed, acceleration, and final speed, with some suggesting the use of specific equations to clarify these relationships.
The conversation is ongoing, with some participants providing clarifications on the equations involved and the physics concepts at play. There is an acknowledgment of the need for clearer questions from the original poster to facilitate better assistance. Guidance has been offered regarding the calculations of velocity and the effects of gravity on the ball's motion.
Participants note the potential confusion stemming from the original poster's understanding of the concepts of initial velocity and the effects of gravity, as well as the implications of calculating motion beyond the point of maximum height.
omgwtf
Say there's a ball being thrown upwards (from the bottom to the top of a building) with an initial speed of 29.4 m/s for 4 seconds at an acceleration of -9.8 m/s².
Now here's a few of my problems:
1.) My book says the ball would stop after 3 seconds. Wouldn't it therefore be pointless to calculate what would happen in 4 seconds?
2.) My book says the end speed (V1/Vf) would be -9.8 m/s. Doesn't the end speed always equal acceleration times time (V1 = at) which would therefore be -39.2 m/s?
Also, what's the difference between starting at rest (with the initial speed being zero) and being thrown (for example, in this case, 29.4 m/s), isn't gravity technically 'throwing' the object in question?
Thanks to anyone who can explain this, it's confusing me a lot. I've only been working with physics (self-teaching) for about 4 days so excuse the newbieness of the question.
I don't think the question is perfectly clear. What you've got though, is a ball thrown upwards at 29.4 m/s, and this is all you need to find that it reaches the top of it's flight, or stops at t = 3 seconds. So the question wants you to find what it's velocity is after 4 seconds - in other words when it has been coming down again for 1 second, which is fairly trivial.
I don't really understand what you're asking with your last question. Here, you are throwing the ball upwards so you have to give it an initial velocity or it won't go anywhere - gravity acts downwards on the ball to slow it down and eventually stop it. Can you clarify a bit if you want a further/better explanation?
I agree with mulder that ur question is not really clear, i am sure that if u make it a little clearer we would be able to help you.
But at the moment, i hope this equation till help you :
Vf=Vi+at
Thanks STAii, that pretty much cleared it up. I was using the wrong formula to calculate 'Vf'. As for my second question, I think I understand it now.
Thanks guys.
"1.) My book says the ball would stop after 3 seconds. Wouldn't it therefore be pointless to calculate what would happen in 4 seconds?"
The ball starts moving upward. Since the acceleration due to gravity is downward, the ball slows down and after 3 seconds comes to a stop. (the acceleration is -9.8 m/s^2. After 3 seconds, the total "change in speed" will be (3s)(-9.8m/s^2)= -29.4 m/s so that the original speed of +29.4 m/s has reduced to 29.4- 29.4= 0 m/s.
But the acceleration still there! The ball doesn't "hang in the air". It still has an acceleration (because gravity is still pulling on it) of -29.4 m/s^2 so after 1 MORE second, it is moving downward at -9.8 m/s. You could have calculated that without worrying about when the ball "stopped" by saying, "since the acceleration is -9.8 m/s, in 4 seconds the change in speed will be (4)(-9.8)= 39.2 m/s. Since the initial speed was 29.4 m/s, after 4 seconds, the speed will be 29.4- 39.2= -9.8 m/s."
"2.) My book says the end speed (V1/Vf) would be -9.8 m/s. Doesn't the end speed always equal acceleration times time (V1 = at) which would therefore be -39.2 m/s?"
Well, first, the end speed is "Vf", not "V1/Vf". I presume you mean V1 to be the initial speed. As long as acceleration is a constant, the CHANGE in speed is "acceleration times time": 4(-9.8)=
-39.2 m/s. However, the final speed will be "initial speed plus change in speed":in this case, 29.4- 39.2= -9.8m/s as we got above.
IF we just dropped the ball from the top of the building, the initial speed would be 0 ("dropped" not "threw up/down") and the speed after 4 seconds would be 0- 39.2= -39.2 m/s.
"Also, what's the difference between starting at rest (with the initial speed being zero) and being thrown (for example, in this case, 29.4 m/s), isn't gravity technically 'throwing' the object in question?"
No, gravity doesn't "throw" anything, it only "pulls"! The "acceleration due to gravity" gives you the change in speed. That has to be added to the initial speed to get the final speed.
If you stand on the roof of the building a DROP the ball (initial speed 0), after 4 seconds its speed will be 0- 39.2= -39.2m/s and the ball will be well below the roof (if it hasn't already hit the ground!).
If you throw the ball upward from the roof at an intitial speed of
29.4 m/s, the CHANGE in speed after 4 seconds will be exactly the same: -39.2 m/s so its speed have decreased from 29.4: 29.4- 39.2 m/s
= -9.8 m/s and the ball will still be well above the roof.
  • · Replies 38 ·
14K
10K
  • · Replies 19 ·
