| Thread Closed |
Static Eqm-unsure about forces to be drawn |
Share Thread | Thread Tools |
| Mar27-09, 08:16 PM | #1 |
A uniform beam of mass mb and length supports blocks with masses m1 and m2 at two positions, as in Fig. P12.3. The beam rests on two knife edges. For what value of x will the beam be balanced at P such that the normal force at O is zero? ![]() 2. Relevant equations sum of F = 0 sum of moments = 0 3. The attempt at a solution I'm quite unsure regarding the forces to be drawn in my free body diagram. Example, the two normal forces by beam on the each masses. Do i draw them out? And at points P and O, is there a horizontal reaction force? How do i determine the forces at point P? Like when i looking at point P, do i think as the way below? (treat the knife edge at O as not existing) the beam can rotate at P, so no moments. but the beam cannot translate horiz and vert at P, so there are horiz and vert reaction forces. or I cannot treat the knife edge at O as not existing? If so, means the beam cannot rotate at P and there will be a moments? Do you all know what i mean? =x Can explain to me? Thanks!! |
| Mar27-09, 11:52 PM | #2 |
Recognitions:
The best treatment is to consider that point O doesn't exist.
Then all you care about are the sum of the moments about P, which you can write out by inspection. As to the forces at P, that's just the Σ m*g if it is in balance. |
| Mar28-09, 03:33 AM | #3 |
Then for the two normal forces by beam on the each masses, are they considered as internal forces? |
| Mar28-09, 07:53 AM | #4 |
Mentor
| Mar29-09, 08:48 AM | #5 |
There are horizontal forces cos the beam cant translate horizontally at these points? (like the support reactions..) hmm.. is it? |
| Mar29-09, 09:56 AM | #6 |
Mentor
If you place a book on a table, what's the horizontal reaction force? Why is that case any different than this one?
| Mar29-09, 10:31 AM | #7 |
| Mar29-09, 10:42 AM | #8 |
Mentor
| Mar29-09, 10:45 AM | #9 |
No force?
| Mar29-09, 10:48 AM | #10 |
Mentor
| Mar29-09, 10:53 AM | #11 |
Means it is not like those support reactions? Like if we cannot rotate abt that point, the there is a moment; if we cannot translate vertically or horizontally, then there is a reaction vertically or horizontally?
| Thread Closed |
| Thread Tools | |
Similar Threads for: Static Eqm-unsure about forces to be drawn
| Forces due to static fluids | Engineering, Comp Sci, & Technology Homework | 2 | ||
| kinetic and static frictional forces | Introductory Physics Homework | 1 | ||
| Static Forces | Introductory Physics Homework | 2 | ||
| static forces | Introductory Physics Homework | 3 | ||
| about electro static forces | Classical Physics | 3 | ||
