Should I Use the Quotient Rule for Derivatives of Fractions?
In summary, the different rules for derivatives with fractional terms can be converted to each other depending on the surrounding expressions.
Liquid7800
76
I would like to know...when trying to take the derivative of a function with a fraction in it ...
should I always turn it into a product and use the product rule, thereby dropping the quotient rule most of the time?
Or is the quotient rule needed more so in some cases?
Its like once you know the power rule etc. why take the derivative using the Definition or Newton Quotient, you can do it...but why would you want to?
Thanks in advance!
I think it depends on the question. I find that it is easier to use the quotient rule in some cases, and product rule in others. They are both really different forms of the same rule (i.e. you can easily derive one from the other), but i don't think you should just forget about one completely; practice using both.
Thanks for the good advice...I plan on practicing both...and I suppose it does depend on the question (ie finding the derivative with the definition...)
Now last question (sorry I am a newbie at calculus)...
whether you use the product rule for a derivative with a fraction in the function, by changing it to a product, or the quotient rule and leave it alone...
both WILL come out to the same answer always right?
Thanks for the reply too.
If you do it correctly, then yea, they will both yield the same answer.
I agree with danago.
The convenience might depend what you want to do with it at the end - although you might not be able to see that at the beginning.
e.g. the first term in the quotient form is vu'/v2 so there is a cancellation where the product form gives you u'v-1 straight for the first term, on the other hand you might be interested in the numerator of the quotient form as a whole for some other factorisation for example. There isn't much in it
Good advice everyone:
I went into my test after studying both ways and realized that I would use one way or the other depending on how the other parts of the expression surrounding a particular part were expressed...eg
If most of the terms were products...I would convert to product as well...if most of them were quotients I would convert to quotients etc...also I find the Quotient rule is good for discerning trig identities easier then converting to product rules.
I find that the quotient rule is easier to work with algebraically, since you already have the lcd(which is the first step of simplifying a derivative found by the using the product on quotient.) Also, if you are interested in zeros/critical points, the quotient rule saves you steps on your algebra as well.
1. What is the Quotient Rule for Derivatives of Fractions?
The Quotient Rule is a formula used in calculus to find the derivative of a fraction. It states that the derivative of a fraction is equal to the denominator squared multiplied by the derivative of the numerator, minus the numerator multiplied by the derivative of the denominator, all divided by the denominator squared.
2. When should I use the Quotient Rule for Derivatives of Fractions?
The Quotient Rule should be used when the function being differentiated is a fraction or can be written as a fraction. It is specifically used when finding the derivative of a function that is in the form of f(x)/g(x), where f(x) is the numerator and g(x) is the denominator.
3. What are the advantages of using the Quotient Rule for Derivatives of Fractions?
The Quotient Rule allows for a quicker and more efficient way to find the derivative of a fraction compared to using the product rule. It also eliminates the need to manipulate the fraction into a form that can be differentiated using other rules.
4. Are there any limitations or restrictions when using the Quotient Rule for Derivatives of Fractions?
Yes, the Quotient Rule can only be used when both the numerator and denominator of the fraction are differentiable functions. It cannot be used when the denominator is equal to 0, as this would result in an undefined derivative.
5. Can the Quotient Rule be applied to higher order derivatives?
Yes, the Quotient Rule can be applied to higher order derivatives. To find the second derivative, simply apply the Quotient Rule to the derivative of the first derivative. This process can be repeated to find higher order derivatives.
  • Mechanics
