Resistance and Resistivity problem
The discussion focuses on calculating the necessary length of Nichrome wire for a heater that dissipates 575 W of power at a voltage of 120 V. The resistivity of Nichrome is given as 100 x 10^-8 ohm-m. The user initially calculated the current as 4.792 Amperes and the cross-sectional area as 0.000232 m². However, they incorrectly derived the length of the wire as 0.1079 m. The correct formula for length is L = (ρV)/(IA), which resolves the issue.
  • Understanding of electrical power equations (P=IV)
  • Knowledge of resistivity and its units (ohm-m)
  • Ability to calculate cross-sectional area of a wire (A=πr²)
  • Familiarity with Ohm's Law (R=V/I)
  • Study the derivation of the formula L = (ρV)/(IA) for wire length calculations
  • Explore the impact of temperature on resistivity in materials
  • Learn about different materials' resistivity values for various applications
  • Investigate the relationship between wire gauge and resistance
Students in physics or electrical engineering, electrical technicians, and anyone involved in designing heating elements or understanding electrical resistance in conductors.
Snowman2526
A piece of Nichrome wire has a radius of 8.6 x 10^-3 m. It is used in a laboratory to make a heater that dissipates 575 W of power when connected to a voltage source of 120 V. Ignoring the effect of temperature on resistance, estimate the necessary length of wire.
Nichrome wire had resistivity of 100x10^-8
p=resistivity
P=power
L=length of wire
A=cross sectional area of wire
I=Current
V=Voltage
R=pL/A
R=V/I
P=IV
I first solved for current, since i'd need to plug resistance into the first equation to make L the only unknown. So P/V=I gives I=4.792 Amperes. Then I needed to take the radius of the wire and make it into cross sectional area, so A=(pi)r^2...A=.000232 m^2.
Now to solve the first equation for L...L=pV/IA.
L=(100x10^-8 ohm-m)(120 V)/(4.792 A)(.000232 m^2)
now, i know I'm getting the wrong answer of .1079 m. can anyone tell me what I'm doing wrong?
Hi Snowman2526! :wink:
(have a rho: ρ :wink:)
Noooo … ρ = (A/L)(V/I), so L = … ? :smile:
thank you sir :) problem solved
  • · Replies 23 ·
  • · Replies 21 ·
12K
