Solve a radical equation where the root is a negative integer?
The discussion revolves around the possibility of solving a radical equation where the root is a negative integer. Participants explore the concepts of radical equations, imaginary numbers, and the definitions of various types of numbers, including complex and irrational numbers.
  • Meta-discussion
  • One participant questions whether it is possible to have a negative integer as a root in a radical equation.
  • Another participant clarifies the terminology, distinguishing between "root" and "radicand," and introduces the concept of imaginary numbers when the radicand is negative.
  • A participant seeks clarification on the logic behind imaginary numbers and their relation to even integer roots.
  • Discussion includes the properties of complex numbers and their operations, with a focus on how imaginary numbers arise from negative radicands.
  • Some participants express their dislike for the term "imaginary numbers," arguing for their validity and utility in mathematics and real-world applications.
  • There is a debate about the terminology surrounding irrational numbers, with participants discussing the historical context and implications of the terms used.
  • Humorous exchanges occur regarding the nature of numbers and their classifications, leading to light-hearted commentary on mathematical terminology.
Participants express differing views on the terminology of imaginary and irrational numbers, with no consensus reached on the appropriateness of these terms. The discussion remains unresolved regarding the initial question of negative integer roots in radical equations.
Some participants reference historical opposition to certain types of numbers and the evolution of mathematical terminology, indicating a complex interplay of ideas that may not be fully resolved in the discussion.
Imparcticle
Is it possible to solve a radical equation where the root is a negative integer?
Mathematics news on Phys.org
I believe you're referring to the "radicand" (the number under the square root sign). Can you be more specific as to what is trying to be solved, what the equation is, where is the radical, etc? I suppose it would be helpful for you to know that there are complex and imaginary numbers, so if you had:
[tex]x = \sqrt{-1}[/tex]
then:
[tex]x = i[/tex]
Where [itex]i[/itex] is the imaginary number defined as the square root of -1.
I was referring to the "root". For example, 1/24=2 when the denominator of the exponent is two. "Two" is the root, "4" is the radicand. Can "two" be negative?
Can you explain to me the logic behind imaginary numbers which apparently result when the radicand is negative and the root is an even integer?
A complex number consists of two real numbers (a,b) along with the summation operation:
(a,b)+(c,d)=(a+c,b+d)
and the multiplication:
(a,b)*(c,d)=(ac-bd,ad+bc)
Note that any complex number on the form (a,0) fulfills every property that a real number has!
An imaginary number is on the form (0,b).
If we make the multiplication (0,1)*(0,1) we get:
(0,1)*(0,1)=(0*0-1*1,0*1+0*1)=(-1,0)
This is the meaning of (0,1) as the "root" -1.
No. By convention I guess, [itex]\sqrt{4}[/itex] and [itex]4^{1/2}[/itex] are [itex]+2[/itex]. If you had a question like [itex]x^2 = 4[/itex], then the answer would be [itex]x=\pm 2[/itex]. Similarly, whereas [itex]\sqrt{4} = 2[/itex], [itex]\pm \sqrt{4} = \pm 2[/itex].
An imaginary number is simply any real number times [itex]i[/itex]. So, if [itex]\sqrt{5.5225} = 2.35[/itex], then [itex]\sqrt{-5.5225} = \sqrt{5.5225} \times \sqrt{-1} = 2.35i[/itex]. You may want to check out the Mathworld.com article on Complex Numbers.
If an exponent is negative, for example 9-1/2, then it is equal to the reciprocal: 9-1/2= 1/(91/2)= 1/3.
I dislike the term "imaginary numbers." These numbers exist as much as any other number exists. They are needed to solve equations like x2 + 1 = 0, and they have many everyday applications. Any wave function involves imaginary numbers, so TV, radio, and microwave ovens exist because of the existence of imaginary numbers.
There is a very elegant branch of mathematics known as complex variable theory which deals in detail with the properties of complex numbers (a number with a real and imaginary part). This theory can be used to greatly simplify the solution of some problems that would be just about impossible to solve otherwise. As a simple example, try to prove the common trig identity Cos(A + B) = CosACosB - SinASinB using standard methods. Using Euler's Formula from Complex Variable Theory, it becomes almost trivial.
While sharing your dislike of that term (for the same reason), I dislike the term "irrational numbers" even more..:wink:
haha - There is at least some justification for the term irrational since these numbers can't be represented as the ratio of two integers.
Not really, the original word "ratio" means reason, and the term "irrational numbers" was explicitly formed to mean numbers that were "unreasonable"..
What are you going on about? Sources? The reason I ask is because this contradicts reality. The word "ratio" is from the Latin to calculate or reckon. Just because something sounds "cool" doesn't mean its right. Obviously, the common usage of rational follows from this definition.
*Nico
Well, that's the explanation I've "always" heard.
It sort of fitted the documented opposition in history from the evolution of new numbers (as in the Pythagoreans' ambivalence to the discoveries of irrational numbers, European mathematicians opposition to negative numbers in the 16'th century, and, about the same time, or a bit later, the coining of term "imaginary" in opposition to "real").
It might well be a myth in the case of irrational numbers, so, assuming that, thx.
How does a real number know that it's not an imaginary number imagining that it's a real number? Of course that would be irrational.
Now that's REALLY COMPLEX, jcsd
Few numbers are PERFECT though :redface:
But most of them are FRIENDLY :biggrin:
Yes I've ceratinly found some numbers are very AMENABLE to my needs *groan*
I think this thread has degenerated into a PRIME example of stupid math jokes..
  • · Replies 41 ·
  • · Replies 31 ·
