| Thread Closed |
The Universal Geometric Set |
Share Thread | Thread Tools |
| Jun11-04, 12:40 AM | #1 |
A simple[trivial?] postulate that gives a "Universal Set" and resolves the "set of all sets" paradox[in the geometric sense]:
A circle of radius R, is isomorphic to a circle of radius 1/R. [1/R]<--->[R] For any arbitrarily large circle of radius R, there is an exact correspondence with a circle of radius 1/R, such, that the product R*[1/R] = 1 |
| Jun11-04, 04:02 AM | #2 |
Recognitions:
and this resolves russell's paradox? so where is the set of all sets that do not contain themselves in this construction? and in what sense are you using isomorphism? in what category are your morphisms?
| Jun11-04, 04:23 AM | #3 |
All circles are isomorphic to each other because they have the same shape. Likewise, all squares are isomorphic to each other. Now if sets can be transformed into geometric shapes, more specifically, circles, or "geometric shape-equivalents", the largest possible set with a geometric radius R, has a corresponding twin with radius 1/R. |
| Jun11-04, 05:07 AM | #4 |
Recognitions:
well, when you've figured out what it is you're trying to prove let us know.
| Jun11-04, 01:09 PM | #5 |
http://en.wikipedia.org/wiki/Euler_characteristic Graph Theory: http://en.wikipedia.org/wiki/Graph_theory If a polyhedron has V vertices, F faces, E edges, and is topologically equivalent to the sphere, the equation is: V + F - E = 2 2 is the "Euler characteristic" of the polyhedron. Sets that are members of themselves correspond to a geometric form. Sets that are not members of themselves correspond to a different? geometric form. Interesting. |
| Jun11-04, 03:06 PM | #6 |
| Jun12-04, 12:00 AM | #7 |
http://www.rdrop.com/~half/Creations...riangleShapes/ The magnitude of R corresponds to the cardinality of the powerset. Is the set of all geometric forms, a geometric form? Can Venn diagrams correspond to light cone cross sections? |
| Jun12-04, 12:43 AM | #8 |
Can I answer your questions with more questions ?
PS : Yes that should have been homeomorphic. But I'm still not getting the point. What is the resolution of the paradox ? |
| Jun12-04, 01:53 AM | #9 |
Set intersection is a type of multiplication of sets. The intersection of two circles of radius R and 1/R, respectively: R*[1/R] = 1 R[<-[->[<-[1/R]->]<-]->] The "Universal Set" For the continual expansion of power set circle R, there corresponds circle[infinitesimal?] 1/R. |
| Jun12-04, 10:54 AM | #10 |
| Jun12-04, 11:52 AM | #11 |
You can have a set A containing millions of even numbers, and a set B containing thousands of odd numbers and you "multiply" them to get a null set ? |
| Jun12-04, 01:15 PM | #12 |
http://www.jgsee.kmutt.ac.th/exell/Logic/Logic31.htm#13 Two sets without common elements are disjoint. |
| Jun12-04, 01:17 PM | #13 |
Venn diagrams are circles... Light cone cross sections are circles, ellipses, etc. |
| Jun12-04, 03:34 PM | #14 |
| Jun13-04, 12:54 AM | #15 |
Since the circle of radius R is isomorphic to the circle of radius 1/R, the cardinality of Circle with radius R is on the same line[radius] as the infinitesimal 1/R 1/R 0--------0 R Since they are on the same line, they intersect. But perhaps a new type of set multiplicative identity needs to be derived? In ordinary quantum mechanics, configuration space is space itself {i.e.,to describe the configuration of a particle, location in space is specified}. In general relativity, there is a more general kind of configuration space: taken to be the space of 3-metrics {"superspace", not to be confused with supersymmetric space} in the geometrodynamics formulation. The wavefunctions[Venn diagrams-light cones] will be functions over the abstract spaces, not space itself-- the wavefunction defines "space itself". The resultant metric spaces are thus defined as being diffeomorphism invariant. Intersecting cotangent bundles{manifolds} are the set of all possible configurations of a system, i.e. they describe the phase space of the system. When the "wave-functions/forms" intersect/entangle, and are "in phase", they are at "resonance", giving what is called the "wave-function collapse" of the Schrodinger equation. the action principle is a necessary consequence of the resonance principle. |
| Jun13-04, 10:08 AM | #16 |
Although you're using the words, you don't seem to be doing mathematics, so I'll move this thread over here.
| Jun13-04, 05:22 PM | #17 |
Recognitions:
| Thread Closed |
| Thread Tools | |
Similar Threads for: The Universal Geometric Set
| universal gravitation | Introductory Physics Homework | 2 | ||
| Universal Expansion | Cosmology | 11 | ||
| universal law of gravitation | Introductory Physics Homework | 1 | ||
| geometric series/geometric progression | Precalculus Mathematics Homework | 2 | ||
| Universal Sequence | Brain Teasers | 3 | ||
