Register to reply
Motion of a Charged Particle in an Electric Field
by zandbera
Tags: charged, electric, field, motion, particle
Share this thread:
zandbera
#1
Mar31-09, 02:40 AM
P: 18
A proton moves at 4.50 x 108 m/s in the horizontal direction. It enters a uniform vertical electric field with a magnitude of 9.60 x 103 N/C. Ignoring any gravitational effects, find (a) the time interval required for the proton to move 5.00 cm horizontally, (b) its vertical displacement during that time interval, and (c) the horizontal and vertical components of its velocity after it has traveled 5.00 cm horizontally.
2. Relevant equations
[tex]\vec{a}[/tex] = q[tex]\vec{E}[/tex] / m
3. The attempt at a solution
(a) Since it's moving at constant horizontal velocity, and the only force its encountering is a vertical force, would the particle continue to move at the constant horizontal speed? Which would mean that the time interval to move 5.00 cm is just its velocity / 5.00 cm??
(b) I don't know how to relate the electric field to the velocity. But I know that the initial vertical velocity is 0, right?
(c) If i was right in (a) then its horizontal component will be the same
Phys.Org News Partner Science news on Phys.org
Study links polar vortex chills to melting sea ice
Lab unveil new nano-sized synthetic scaffolding technique
Cool calculations for cold atoms: New theory of universal three-body encounters
Doc Al
#2
Mar31-09, 07:39 AM
Mentor
Doc Al's Avatar
P: 41,489
Quote Quote by zandbera View Post
Right.
You have that fraction upside down. Distance = velocity*time.
But you know how to find the acceleration caused by the electric field. The rest is kinematics.
Right.
That's true.
zandbera
#3
Apr1-09, 12:16 AM
P: 18
(b) From the equation and my given data, is qE = 9.60 x 10^3 N/C or is it just E = 9.60 x 10^3?
If it's E = 9.60 x 10^3, I would just multiply by (+e) to get qE and then divide by the mass of a proton, right?
zandbera
#4
Apr1-09, 12:46 AM
P: 18
Okay yeah for (b) I did what I thought, I used E = 9.60 x 10^3, then multiplied by +e, divided by mass of proton to get a, then used delta x = Vi t + 1/2 a t^2 with Vi = 0, and i got 5.68 mm, the correct answer.
So then for (c), the horizontal component is just the initial horizontal velocity, and then i can use the time interval from (a) and the acceleration from (b) to find the vertical velocity, so would those be my two components?
Doc Al
#5
Apr1-09, 07:23 AM
Mentor
Doc Al's Avatar
P: 41,489
Right!
Register to reply
Related Discussions
Force on charged particle to enter electric field perpendicularly! General Physics 4
Electric field affecting a charged particle question Introductory Physics Homework 1
Motion of charged particle in a magnetic field Advanced Physics Homework 1
Help please, motion of charged particle in mag field Introductory Physics Homework 4
Motion of Charged Particle in a Magnetic Field Introductory Physics Homework 1
