| Thread Closed |
Is this possible? [Pythagorean theorem in 3D] |
Share Thread | Thread Tools |
| Mar31-09, 04:57 PM | #1 |
Imagine the shape you would get if you chopped off the corner of a cube (the *smaller* corner piece with 4 sides and 6 edges).
Can the area of the largest side be expressed in terms of the areas of the 3 smaller sides? Like the Pythagorean theorem in 3D. How would I go about finding/proving the answer? |
| Mar31-09, 05:07 PM | #2 |
Recognitions:
The distance in 3D is the same Pythagorus theorem = sqrt( x2 + y2 + z2 )
| Mar31-09, 05:09 PM | #3 |
Hi Georgepowell!
![]() Well, the largest side is an equilateral triangle, and its edge is √2, so its area is … ?
| Mar31-09, 05:43 PM | #4 |
| Mar31-09, 05:53 PM | #5 |
Recognitions:
Yes, it is true that for a right tetrahedron, the square of the area on the diagonal face is equal to the sum of the squares of the areas of the other three faces.
D^2 = A^2 + B^2 + C^2 Try to figure out how to prove it. An analogous theorem holds in higher dimensions: for a right n-simplex, the square of the (n-1)-volume of the diagonal face is equal to the sum of the squares of the (n-1)-volumes of the other faces. |
| Mar31-09, 05:54 PM | #6 |
ok … then the area times the normal unit vector is 1/2 (b - a) x (c - a) = 1/2 (b x c + c x a + a x b) …
so the area is the magnitude of that … which you can find by using Pythagoras.
| Mar31-09, 06:12 PM | #7 |
) I will have a crack at proving it, although if I struggle I will ask for a clue. |
| Mar31-09, 06:15 PM | #8 |
If not, ignore what I said.
| Mar31-09, 06:25 PM | #9 |
| Mar31-09, 07:30 PM | #10 |
However, an illustrative first step would be to prove tiny-tim's special case, where all the right triangles are mutually congruent and the base triangle is therefore equilateral. |
| Mar31-09, 08:11 PM | #11 |
Heron's formula for the area of a triangle in terms of it's perimeter came in really handy for me here. With that in hand, it was just plug and chug. Now, if my right triangles have area A, B, and C, then I'm really hoping for the area of my "hypotenuse-like" triangle to have an area D like...
[tex]D = \sqrt{ A^2 + B^2 + C^2} [/tex] ... to be perfectly analogous to the two dimensional Pythagorean. However, that's not what I got. I have an extra factor of [tex]\sqrt 2[/tex] in my calculation. It's worth someone double checking this, but I'm convinced that there is a 3D analog of the Pythagorean theorem, with a form similar but not identical to the 2D version. Nice question, George! Okay, here's a related one. Prove the converse of the 3D Pythagorean theorem. In other words, given a pyramid whose faces obey the certain relation for their areas, must three of those sides meet at a vertex with all right angles? |
| Mar31-09, 08:19 PM | #12 |
So my root two factor was indeed spurious, and I'm now in agreement with Ben Niehoff's formula.
| Apr1-09, 04:15 AM | #13 |
Hi Georgepowell!
![]() just got up … ![]() the area of a triangle is 1/2 bc sinθ, which happens to be the same as the magnitude of the cross product 1/2 b x c, assuming the vertices are at 0 b and c. b x c, of course, is a vector: its magnitude is twice the area of the triangle, and its direction is normal (perpendicular) to the triangle. In the more general case where the third vertex is at a (not 0), the sides are b - a and c - a, and so the area times the normal unit vector is 1/2 (b - a) x (c - a) = 1/2 (b x c + c x a + a x b) Square that, put the origin at the vertex of the cube, so that (b x c) x (c x a) = 0 and so on (can you see why?), and you get the result.
| Apr1-09, 12:38 PM | #14 |
It turned out that today in Maths we learnt about the dot product of two vectors, it looks very similar to the cross product. The way I understand it:
The cross product of two vectors axb =|a|*|b|*sin(θ) [vector, perpendicular to a and b] The dot product of two vectors a.b =|a|*|b|*cos(θ) [scalor] The dot product a.a is equal to the area of a square with side lengths a. (because cos(0) = 1) The size of the cross product axb is equal to the area of a parallelogram made with the vectors a and b. I was playing around with these two tools and I proved the original Pythagorean theorem (I think). Here goes: A right angled triangle has two smaller sides represented by vectors a and b. 0.5*[a.a+b.b] is the sum of the squares of the two smaller sides. 0.5*[(a-b).(a-b)]=a.a+b.b+2*a.b a and b are at right angles to each other so 2*a.b = 0 And that is it, the rest is obvious! The proof of the equation D²=a²+b²+c² for a pyramidy thingy with three sides given as vectors a, b and c: The area of the larger side is given by 0.5*the area of a parallelogram formed by the two sides. The area of the larger sides = 0.5*|(b-c)x(a-c)| Expanding the cross product I got =0.5*|cxa+cxb+axb| The vectors are all perpendicular to each other, so |cxa|=|c|*|a|. Then to find the size of this final vector I used Pythagoras' theorem (because each of the individual vectors are perpendicular to each other). =0.5*√[(|c|*|a|)²+(|b|*|a|)²+(|b|*|b|)²] The 0.5 on the outside can be turned into 0.25, and brought inside the square root. Then it can be brought into each individual square, to get: 0.5*√[(|c|*|a|)²+(|b|*|a|)²+(|b|*|b|)²]=√[(0.5*|c|*|a|)²+(0.5*|b|*|a|)²+(0.5*|b|*|b|)²] And it is obvious that 0.5*|c|*|a| is the area of the triangle on the side of the pyramidy thing. This post looks a bit messy, I think it makes sense though |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Is this possible? [Pythagorean theorem in 3D]
| Pythagorean Theorem and Pendulums | Introductory Physics Homework | 5 | ||
| Pythagorean Theorem. | General Math | 9 | ||
| Pythagorean Theorem | Precalculus Mathematics Homework | 6 | ||
| 3-D Pythagorean Theorem? | General Math | 19 | ||
| How many ways are there to prove Pythagorean Theorem? | General Math | 6 | ||
