Calculate Length of Transmitting Antenna for 1.8 GHz Frequency
  • Thread starter Thread starter XodoX
    Antenna
The discussion focuses on calculating the length of a monopole antenna for a cell phone operating at a frequency of 1.8 GHz. The wavelength (λ) is derived using the formula λ = c/f, where c is the speed of light (2.99792458 × 10^8 m/s). The correct calculation reveals that the antenna length should be approximately 4 cm. Participants emphasize the importance of converting the speed of light to centimeters per second for accurate results.
  • Understanding of electromagnetic wave propagation
  • Familiarity with antenna theory and design
  • Basic knowledge of frequency and wavelength calculations
  • Ability to convert units (meters to centimeters)
  • Study the principles of monopole antennas
  • Learn about the relationship between frequency and wavelength in RF engineering
  • Explore unit conversion techniques in physics
  • Research antenna tuning and matching for optimal performance
Electrical engineers, RF engineers, and hobbyists involved in antenna design and optimization for mobile communications.
XodoX
Hello, I got the following problem.
1. Assuming that your cell-phone antenna acts like a monopole, how long should it be if the
cell phone operates at a frequency of 1.8 GHz? (Note: 1 GHz = 1000 MHz =
1,000,000,000 Hz.)
2. λ= c/f
f would 1/T, T being the Hz. But that would be 0,0000000001
Then, c is always the same value, right? Which would be c = 2.99792458 × 108 [m/s].
I can't get the result. It's supposed to be about 4 cm:confused:
Hello XodoX! :smile:
Convert c to cm/s :wink:
