Magnetic Field - Torque on a Current Loop
The discussion focuses on calculating the current in a circular coil with 720 turns and an area of 0.6 m² placed in a uniform magnetic field of 0.63 T, where the maximum torque is 0.0026 N·m. The equation used is T = IABn, which allows for the determination of current in the coil. The second part of the problem involves recalculating the current when the coil is transformed into a single-turn coil with a larger area, where the relationship A2 = (n²)A1 is crucial for finding the new area and subsequently the current.
  • Understanding of magnetic torque equations, specifically T = IABn
  • Knowledge of circular coil properties and magnetic fields
  • Ability to manipulate algebraic equations for problem-solving
  • Familiarity with the concept of turns in coils and their effect on magnetic properties
  • Study the derivation and applications of the torque equation T = IABn
  • Explore the relationship between coil turns and magnetic field strength
  • Learn about the effects of area changes on torque in magnetic fields
  • Investigate practical applications of current loops in electromagnetic devices
Students studying electromagnetism, physics educators, and anyone interested in the practical applications of magnetic fields and current loops in engineering and technology.
calvert11
A circular coil of 720 turns and area 0.6 m^2 is in a uniform magnetic field of 0.63 T. The maximum torque exerted on the coil by the field is 0.0026 N · m.
a) Calculate the current in the coil.
b) Assume the 720 turns of wire are used to form a single-turn coil with the same shape but much larger area. What is the current if the maximum torque exerted on the coil by the field is 0.0026 N · m?
NOTE: Sigfigs do not matter
T = IABn
Part A:
I solved by substitution using the equation T = IABn, getting T = 9.5532e-6 N · m (answer is correct)
Part B:
This is the part I'm having trouble with. I thought I could fine the new Area doing the following (I'm sure this approach is wrong):
.6 = pi*r^2, r*720 = 314.7
A = pi*314.7^2, plugging in the new area into T = IAB gives the wrong answer.
I'd be very grateful for any help.
I got 1.32644e-8 N-m
yeah, Thanks. I got the same answer or thereabouts.
After some algebra (and some help) I found that the new area A2 = (n^2)*A1.
Plugging that into T = IAB gives the correct answer.
  • · Replies 37 ·
