Double Integral of (x+y)x over a Quadrilateral Region R
The discussion revolves around finding the double integral of the function (x+y)x over a quadrilateral region defined by specific vertices. The participants are exploring the complexities of setting up the limits of integration for this region.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the need to divide the region into two parts and question how to determine the limits of integration for these regions. Suggestions include considering a linear variable change to simplify the limits, and exploring the gradients of the sides of the quadrilateral.
The conversation is active with various approaches being proposed. Some participants are attempting to clarify the shape of the region and its properties, while others are exploring different variable transformations to facilitate the integration process. There is no explicit consensus yet, but several productive ideas are being shared.
Participants note that the region is not a standard shape like a square or rectangle, but rather a parallelogram, which influences the approach to finding the limits of integration. The discussion includes considerations of slopes and equations of lines that define the edges of the region.
aks_sky
Find the double integral of:
(x+y)x dxdy
Where R is a quadrilateral with vertices at (-4,-1), (-2,-2) (-1,1) and (-3,2)
**I have done the diagram and i know that there will be two regions R1 and R2 but i am not sure exactly how to find the limits of int. for these two regions, any suggestions?
thanx
i drew this quickly, but looks like a rotated square to me, so you could think about a linear variable change to make the limits of integration independent & simple
How about taking the gradient of the 2 sides of the square? i think that might work. i will give that a try
i'm not totally sure what you mean...
I was thinking along the lines of new variables u,v, whose level curves are lines parallel to the edges of the squares
Neither a square nor a rectangle- it is parallelogram. Two sides are of length [itex]\sqrt{5}[/itex] and the other two of length [itex]\sqrt{10}[/itex]- and the sides are not perpendicular. However, it can be done as lanedance suggests: The lines through (-2,-2) and (-1,1) and through (-4,-1) and (-3,2) both have slope (1+2)/(-1+2)= 3. The first line is y= 3x+ 4 and the second y= 3x+ 7. If you let u= y- 3x, then the first line is u= -4 and the second u= -7. The lines through (-1, 1) and (-3, 2) and through (-2, -2) and (-4, -1) both have slope (2-1)/(-3+1)= -1/2. The first line is y= -(1/2)x+ 1/2 and the second is y= (-1/2)x- 1. If you let v= y+ (1/2) x, then the first line is v= 1/2 and the second is v= 1. Make that change of variables and don't forget to change the dxdy properly.
So basically i am solving it for dudv by making that change of variable. sweet
  • · Replies 19 ·
  • · Replies 17 ·
