A question about solving the energy eigenvalue of a given Hamiltonian operator
The discussion revolves around solving the energy eigenvalue problem for a Hamiltonian operator representing a particle subject to a harmonic force and a homogeneous electrostatic field. Participants explore methods for addressing the problem, including the calculation of energy eigenvalues and the probability of finding the system in a specific quantum state.
  • Homework-related
  • One participant presents the Hamiltonian operator and requests methods for solving the energy eigenvalue problem and calculating probabilities related to the ground state.
  • Another participant suggests completing the square for the x-dependent part of the Hamiltonian to recognize it as a shifted harmonic oscillator, emphasizing the importance of retaining a constant term.
  • A follow-up request for clarification on the eigenvalue of the completed square expression indicates a need for further detail on the mathematical manipulation involved.
  • Further elaboration is provided on the eigenvalue equation, showing how the transformation leads to a shifted origin and energy in the context of the harmonic oscillator.
  • Participants express appreciation for the assistance and indicate ongoing efforts to solve the problem.
Participants generally agree on the approach of completing the square and transforming the Hamiltonian, but the discussion remains open-ended as no consensus is reached on the final steps or specific eigenvalues.
The discussion does not resolve the mathematical steps required to fully solve the eigenvalue problem, and assumptions regarding the parameters of the Hamiltonian are not explicitly stated.
ee_mike
The problem is
A particle of mass m and electric charges q can move only in one dimension and is subject to a harmonic force and a homogeneous electrostatic field. The Hamiltonian operator for the system is
H= p2/2m +mw2/2*x2 - qεx
a. solve the energy eigenvalue problem
b. if the system is initially in the ground state of the unperturbed harmonic oscillator, ket= |0>, what is the probability of finding it in the ground state of the full Hamiltonian?
Could anybody offer some methods to handle this question? Thank you very much.
I take it you have solved the harmonic oscillator.
This question is pretty much the same. The trick is to complete the square of the coordinate x-dependent part. That is, turn this:
[tex]ax^2 + bx[/tex]
into this:
[tex]a(x+\frac{b}{2a})^2 - (\frac{b}{2a})^2[/tex]
From there you should recognise the harmonic oscillator, only this time with some shifted origin plus a constant term in you Hamiltonian (which you shouldn't throw away).
into this:
Could you explain more detailedly? Because I wonder what is the eigenvalue of [tex]a(x+\frac{b}{2a})^2 - (\frac{b}{2a})^2[/tex]
Thank you very much, you really helped me.
So you start out with the basic eigenvalue equation:
[tex]H\psi = E \psi[/tex]
where, for simplicity, we have
[tex]H = T + ax^2 + bx[/tex]
where T is short for the kinetic energy.
Filling this in gives you the following eigenvalue equation:
[tex](T + ax^2 + bx )\psi = E \psi[/tex]
Now you perform the trick I explained earlier, which give you:
[tex]\left(T + a(x+\frac{b}{2a})^2-(\frac{b}{2a})^2\right)\psi = E \psi[/tex]
or:
[tex]\left(T + a(x+\frac{b}{2a})^2\right)\psi = (E+(\frac{b}{2a})^2) \psi[/tex]
Compare this with the standard form of a harmonic oscillator:
[tex]\left(T + \frac{m\omega}{2} y^2\right)\psi' = \epsilon \psi'[/tex]
As you can see, you now have a shifted origin of the harmonic oscillator, and a shifted energy.
I already brought you more than halfway there, so good luck with the rest of the steps ;)
or:
You are so powerful. I have been doing on this problem since this morning. Thank you very much.
  • · Replies 16 ·
