Can a New Theory of 3D Space Revolutionize Our Understanding of Physics?
  • Context: Graduate
  • Thread starter Thread starter thelovegoose
    3d Space Theory Work
The discussion revolves around a proposed theory of 3D space that challenges traditional views of motion and the nature of space. Participants explore the idea of space as a solid medium composed of discrete "pixels" or "voxels," rather than a void in which objects move. The conversation touches on concepts from physics, mathematics, and computer science, with a focus on the implications of this model for understanding motion and energy.
  • One participant suggests that traditional physical theories view space as a void filled with matter, questioning the validity of this model and proposing an alternative where space consists of discrete pixels with varying properties.
  • Another participant discusses the concept of virtual particles and quantum fluctuations, arguing that even in a vacuum, energy exists, which complicates the notion of a void and suggests that motion may not be possible in such a framework.
  • A later reply challenges the pixel model by introducing the concept of momentum, stating that a "moving pixel" does not carry momentum, unlike physical objects.
  • Another participant introduces the term 'voxels' and compares the proposed model to the behavior of electrons in electrical currents, emphasizing the necessity of force carriers for movement.
Participants express differing views on the nature of space and motion, with no consensus reached. Some support the idea of space as a solid medium, while others raise concerns about momentum and the implications of such a model.
Participants reference concepts such as virtual particles, quantum fluctuations, and momentum without resolving the underlying assumptions or definitions. The discussion remains open-ended regarding the implications of the proposed model on established physics.
thelovegoose
Okay, first of all I'm not a physicist, but I am a mathematician and programmer.
I've been working on a computer game recently and its got me thinking about physics :)
I'm hoping someone here will be able to point me at a theory that encompasses what I've been thinking about, or reasons why its nonsense...
From what I've picked up in the very informal physics education I've had, most if not all physical theories of 3d space seem to be based on the model of a void partially filled with stuff that moves around in it.
What evidence is there to suggest that it isn't a solid space made of 3d "pixels" that have a number of different properties. So instead of something moving from A to B, the properties at pixel A are reset and the properties of B become what was at A. In case that's not clear - think of a white dot moving one pixel to the right on your otherwise black computer screen. It appears that the dot has moved, but in fact the original pixel has turned black and the destination pixel has turned white.
Any feedback greatly appreciated :)
For info, I am intending to study physics properly soon
I think it is generally accepted that there really isn't any 'void'. That even free space has a certain amount of energy even when there is no matter present. The energy is a result of 'virtual particles' popping into and out of existence. The virtual particles are inferred from Heisenberg's uncertainty principle. The principle says that there is a theoretical limit to the knowledge you can have of energy and time simultaneously. With regards to position and momentum(on which there is a similar limit) this fact was interpreted as evidence that a particle really does not have an exact position and momentum. And it's not just that we don't know these quantities, nature doesn't know them. So, because this must also apply to energy and time, you can't have precisely zero energy anywhere, even in a vacuum. There must be quantum fluctuations in energy. These fluctuations are interpreted as virtual particles. This all seems like nonsense but I think this energy has been detected. It was called the Casimir effect.
It seems like the idea that there is no void would prove that motion is impossible. Things would'nt have anywhere to go. Perhaps an infinite space would fix this problem. Or perhaps, like you said, this would'nt matter because what we have is not motion at all, but just the propagation of change in the characteristics of particular points in space. Like a change in color of particular pixels to simulate an object moving across the screen.
Then you need to explain the presence of momentum. A "moving pixel" on your computer screen carries no momentum. A moving object does.
Zz.
3d pixels are called 'voxels', you may want to look that up learn about them. Your black and white pixel example is a bit confusing to me, but consider the model of electrical current where electrons occupy 'holes' and the electrons move from one hole to the next. There is clearly a momentum experienced by the electrons. Remember, one hole cannot be filled unless the electron moves from an adjacent hole and something must cause this movement. This something is a force carrier, also called a boson and in the case of the electron the force carrier is a photon.
  • · Replies 0 ·
  • · Replies 21 ·
  • · Replies 20 ·
  • · Replies 41 ·
15K
