Euler created a time series solution to the function Li(x) and Riemann named it the ξ
function adding his own solution to Euler’s work.
In Riemann’s words “a value x is the root of a function f(x) if f(x)=0. A root of the
function ξ(x) is real if and only if the root of the zeta function is complex number with
real part equal to ½”.
Proving the real part to be ½ was left undone by Riemann. Hilbert later on added, finding
the proof for Riemann hypothesis as one of the problem that remain un resolved in
Mathematics.
I start where Riemann left his hypothesis without the proof.
As said earlier
Now,
Assume
Now to get the Error estimate we add п/ln(x) to the above function.
Then if we graph the zeta function
we see the root falling at exactly
That is area under the graph between 2 and ½ is zero.
If this integral is evaluated between 2 and ½ we will see that the zeta function going to 0.
The integral is evaluated using Cauchy’s principal number 1, between limits 2 and 1 and
then 1 and 1/2
That is,
= 1/(2. ln (1)) – 4/(2. ln(4)) + 0.707/(2.ln(0.707) – 1/(2.ln(1)) =0
This concludes the proof that Rieman’s Zeta function has it’s root as ½ +/- i0 since the area under the under the zeta function between these limits 2 and 1/2 is zero. We can reduce the zeta function to a second order differential equation which is seen to be elliptical in nature.
Error Estimate Note
Taking the McLauien series of the Zeta function in proper form,
ie; f(0)= A0 + A0 . f’(0)/1! +A(0) f “(0)/2!+…….., we see that it grows at the rate of п
Taking A0=1 the initial r of the Spiral observed by taking the polar form of the Zeta
function we have,
F1(0)=1+1. (dr/dt)/1! =2
F2(0)=1+2. (dr/dt)/1!=3 and so on.
If we take trigonometric scale these become п, 2п, 3п and so on.
which makes the error estimate as
п x 1/ln(x) or п/ln (x).
Here we see that the Zeta function grows at the rate of √2 or ln(п) as x grows as e√2=п, which is
the proper form of en.log n the
exponential growth which shows that zeta function values
changes by 1.414 for each successive change in x which gives the zeta function it’s
meaning..
The Spiral observed can be the spiral similar to the Planetary spiral of the Solar System
or the Milky way.
Conclusion
Rieman’s Zeta function whose roots are ½ +/-0 remain proved.
Reference: “God Created Integers” Steven Hawkings PP822
______________
Mathew Cherian
[/tex]
