Thread Closed
single crystal and poly crystal metal
Share Thread Thread Tools
Apr3-09, 09:11 PM   #1
What difference would you observe about the yield stress, young modulus,etc if your material were a single crystal? Explain the difference.
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Researchers use light projector and single-pixel detectors to create 3-D images
>> GPS solution provides 3-minute tsunami alerts
>> Single-pixel power: Scientists make 3-D images without a camera
Apr4-09, 06:38 AM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Please show your own work first. Also, it looks like this and your other questions would be a better fit in the homework forum.
Apr4-09, 06:40 AM   #3
my ans is:If the material were a single crystal, the yield stress would be lower. The dislocation could move easily because there is only 1 crystal. In addition, single crystal metals have directional stiffness. But I'm not sure about that
Apr4-09, 06:52 AM   #4
Recognitions:
Sounds good. To fill this in further, I'd mention the relative difference between the yield stress and Young's modulus for the two types of samples (i.e., is [itex]\sigma_y[/itex] half as much for a single crystal? A thousandth as much? Similarly, does the Young's modulus in different directions vary by a factor of two? A factor of a thousand?).
Apr4-09, 06:55 AM   #5
Thax, I'll think about it
May11-10, 08:55 AM   #6
I came to this forum to learn more about single crystal casting/properties/etc. Sooooo, instead of starting a new thread I will just continue this one.
Quote by Mapes View Post
And the answer to this barrage was? I've taken my fair share of materials courses and the only time single crystals are brought up, it is just to discuss that they are used for fan blades. Or that processing is """expensive""" with no comparative examples.
Can single crystal structures be heat treated to different phases? If they have dislocations, this implies that they can be forged/annealed/work hardened/etc, no? How would the UTS and modulus in the preferred (maximum value) direction compare to a polycrystalline sample of the same dimensions?
I know cost is a big prohibitor, but why have we not seen single crystal casting methods used to create parts in applications like MotoGP, F1, and others? It seems that their only purpose is to make fan blades and computer chips.
May18-10, 01:38 PM   #7
Any help here? Seems like I couldn't find anything on my own for a reason....
May18-10, 01:59 PM   #8
Recognitions:
The advantage of single crystals (in mechanics) is that grain boundary creep is removed as a creep mechanism. If grain boundary creep isn't the dominant cause of failure, then nobody's going to spend money to grow a single metal crystal part.
May18-10, 07:45 PM   #9
Seems to me like they could find a place in IC engines.....if anyone knew more about them.
Thread Closed
Thread Tools
Similar Threads for: single crystal and poly crystal metal
Thread Forum Replies
Does anyone know about crystal cut? Materials & Chemical Engineering 0
Dear Sir, How do we know that crystal is single and perfect? General Physics 4
crystal General Physics 4
crystal ID Chemistry 1
