Thread Closed
Help me to Create a MATLAB program to design a custom voltage divider
Share Thread Thread Tools
Apr4-09, 06:57 AM   #1
Input:
The input values will be provided by the program customer or user
Input voltage. The power that the customer or user of the program has a available to drive the voltage divider.
Output voltage. The desired output voltage chosen by the customer.
Maximum output current. The maximum current the divider is to provide for customer use. This assume that the input power source the customer is providing can also provide a maximum level of current sufficient to drive the divider at its maximum output rating.
Percent load regulation. This is how much the output voltage drops from its no load value to its full load value expressed in percent.
Percent load regulation= ((VoutNL – VoutFL)* 100%
Output:
The outputs will be provided in the form of a list on the display terminal.
Splash screen or banner displayed to the user upon program start up.
Instructions on the display while the program is executing explicitly instructing the user how to use each step of the program.
Value of two resistor in the divider.
Wattage rating of the two resistors in the divider.
A graphic display of the circuit schematic.
Splash screen or banner thanking the customer for using the software
2. Relevant equations
3. The attempt at a solution
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Apr5-09, 02:50 AM   #2
Recognitions:
This is not DoMyHomeworkForMe Forums. Please post your ideas, and where it is that you're getting stuck. For instance, do you know how to take in user input with MATLAB? If you just post your assignment description with nothing else, that's all you'll get: nothing.
Thread Closed
Thread Tools
Similar Threads for: Help me to Create a MATLAB program to design a custom voltage divider
Thread Forum Replies
voltage divider Engineering, Comp Sci, & Technology Homework 12
Voltage Divider Help Electrical Engineering 1
Potentiometer/voltage divider?!?? Electrical Engineering 5
voltage divider problem Electrical Engineering 2
How do voltage-divider & current-divider work; physically? General Physics 2
