Help with single-plane rotor balancing
  • Thread starter Thread starter tpt60
    Rotor
The discussion focuses on the relationship between angular velocity and rotor imbalance correction. It is established that angular velocity does not influence the calculations for the size and placement of correction weights. When these calculations are performed accurately, the rotor achieves balance, ensuring that forces on bearings remain unaffected by angular velocity. This conclusion emphasizes the importance of precise mathematical calculations in rotor balancing.
  • Understanding of rotor dynamics
  • Knowledge of angular velocity concepts
  • Familiarity with correction weight calculations
  • Basic principles of bearing forces
  • Research mathematical methods for rotor balancing
  • Explore advanced rotor dynamics simulations
  • Learn about the impact of bearing forces on rotor performance
  • Investigate tools for measuring angular velocity in rotors
Mechanical engineers, rotor system designers, and anyone involved in the maintenance and optimization of rotating machinery will benefit from this discussion.
tpt60
concerning a rotor with an imbalance, how does the angular velocity of the rotor affect calculations about the size and placement of the correction weight?
angular velocity doesn't affect it
the higher the angular velocity - the greater forces on bearings. if you calculate the size and placement of the correction weight mathematically accurate, a rotor will have no imbalance, so force on bearings won't be dependent on angular velocity.
  • · Replies 18 ·
