| Thread Closed |
intensity, photons, human eye |
Share Thread | Thread Tools |
| Apr4-09, 05:27 PM | #1 |
hi there. there's an example in the book, but i'm having a little trouble here.
1. The problem statement, all variables and given/known data Assume that the human eye can pick up as few as 9 photons/s in the visible range. Based on this, estimate the intensity of the dimmest star that can be detected by a night-adapted eye. What is the ratio of this intensity to the intensity of noon sunlight, some 1400 W/m2? This large intensity range means that the eye is indeed a very adaptable instrument. Answer format = (intensity of 9 photons/s / intensity of noon sun) use 3mm for the radius of the pupil. use 550 nm for wavelength. 2. Relevant equations I=Power/Area I=N*E, N is the number of photons/(m^2*s) E=h*f f=c/lambda A=Pi*r^2 3. The attempt at a solution So I want the intensity, which is N * E, which is (N * h * c) / (Pi * r^2 * lambda). I get the intensity of the dimmest star on the human eye as 1.14592 * 10^(-13). With the given intensity of noon sunlight (do I need to adjust this for the area of the pupil?...), I divide it. 1.14592*10^(-13) / 1440 = 7.95775*10^(-17). but this is wrong, so... either I was supposed to adjust the noon intensity, or I've made one or several other mistakes. I'd appreciate any insights or tips. Thanks! ,Yroyathon |
| Apr3-10, 02:10 AM | #2 |
your equation is correct
check ur calculations^_^ |
| Apr3-10, 03:37 AM | #3 |
I got the same numbers. Why do you think it's wrong? What do you think the right answer is?
| Apr3-10, 12:12 PM | #4 |
I got 1.150429803e-13 for the intensity of the star
divide it by 1400, the final answer should be 8.217e-17 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: intensity, photons, human eye
| Relationship between light wavelength, intensity and photons energy | Introductory Physics Homework | 3 | ||
| Effect of frequency & Intensity on number of photons | Advanced Physics Homework | 3 | ||
| Sound Intensity and Human threshold for hearing | Introductory Physics Homework | 1 | ||
| Shortest Non-Ionizing Wavelength for human body at any intensity/duration? | General Physics | 4 | ||
