Operation amplifier audio equalizer
  • Thread starter Thread starter swuster
    Amplifier Audio
The discussion focuses on constructing an audio equalizer circuit using operational amplifiers (op-amps) to provide variable gain for bass, midrange, and treble frequencies. The proposed solution involves cascading three band-pass filters, each equipped with variable resistors for gain adjustment. However, participants suggest exploring alternatives that utilize a single op-amp with parallel variable resistors to simplify the design. Additionally, the use of SPICE simulation software is recommended for circuit testing before physical implementation.
  • Understanding of operational amplifier (op-amp) configurations
  • Knowledge of band-pass filter design
  • Familiarity with variable resistors and their applications
  • Experience with circuit simulation tools like SPICE
  • Research single op-amp equalizer circuit designs
  • Learn about band-pass filter design principles
  • Explore SPICE simulation techniques for circuit testing
  • Investigate alternative methods for frequency separation in audio applications
Electronics engineers, audio engineers, hobbyists designing audio equipment, and students studying circuit design will benefit from this discussion.
swuster
I am to construct a circuit which can provide variable gain for the bass, midrange, and treble frequencies of an input. One of the stipulations is that I should use as few elements as possible.
n/a
Right now the only solution I can think of is cascading three band pass filters, each with cutoffs for the frequencies relating to bass, mid-range, and treble, and each with variable resistors to change the gain, but I think there's probably a better way to implement this. Is there a way to separate the various frequencies so that I can connect three variable resistors in parallel and use only one op amp, as opposed to three?
Do you have a version of SPICE? There are various free versions available on the internet and it would be a good idea to simulate your ideas before building a circuit.
  • · Replies 27 ·
  • · Replies 29 ·
