Coefficient of Static Friction on a Banked Curve
The discussion revolves around determining the coefficient of static friction required for a car to navigate a banked curve without skidding, given specific speeds and a radius. The problem involves concepts from dynamics and circular motion, particularly focusing on forces acting on an object in a curved path.
  • Mixed
  • The original poster attempts to derive the coefficient of static friction using equations related to centripetal acceleration and forces acting on the car. Some participants question the setup of the free body diagram and the application of trigonometric components in the equations. Others suggest considering additional forces when the speed exceeds the optimal level.
Participants are actively exploring the relationships between forces on a banked curve, with some providing insights into the necessary equations for balancing forces. There is acknowledgment of the need to account for friction at higher speeds, and while some guidance has been offered, there is no explicit consensus on the final approach to solving the problem.
There is mention of confusion regarding the application of trigonometric functions in the context of forces acting on the incline, as well as the original poster's uncertainty about their free body diagram. Additionally, the discussion reflects the constraints of the homework context, where complete solutions cannot be provided.
wingman358
If a curve with a radius of 90 m is properly banked for a car traveling 68 [tex]\frac{km}{h}[/tex], what must be the coefficient of static friction for a car not to skid when traveling at 98 [tex]\frac{km}{h}[/tex]?
I know I need
[tex]\Sigma \vec{F} = m \vec{a}[/tex][tex]f_s <= \mu_s N[/tex]
and
[tex]a_c = \frac{v^2}{r}[/tex]
I first solved for [tex]\theta[/tex], which is the angle of embankment at which a car traveling 68 [tex]\frac{km}{h}[/tex] will need no friction to travel along a curve of radius 90 m.
Given
with pertinent variables:
[tex]f_s = ma_c[/tex]
substituting for [tex]a_c[/tex]:
[tex]f_s = m\frac{v^2}{r}[/tex]
substituting for [tex]f_s[/tex]:
[tex]\mu_s N = m\frac{v^2}{r}[/tex]
substituting for [tex]N[/tex]:
[tex]\mu_s mg\tan{\theta} = m\frac{v^2}{r}[/tex]
dividing by m:
[tex]\mu_s g\tan{\theta} = \frac{v^2}{r}[/tex]
solving for [tex]\mu_s[/tex]:
[tex]\mu_s = \frac{v^2}{gr\tan{\theta}}[/tex]
Now substituting in for all known variables ([tex]v, g, r, and \theta[/tex]), [tex]\mu_s[/tex] equals 2.077, which MasteringPhysics does not accept.
Now, I'm very confused on this problem, mainly because I'm unsure if my free body diagram is correct:
http://img227.imageshack.us/img227/5083/physfbd.th.png
Note: image is not to scale
Any help or hints would be appreciated!
Strictly speaking, when the speed is balanced to the curve you really have
Cosθ *m* V2/R = Sinθ *m*g
To balance that equation however when the speed is greater than optimal you have a frictional force that is made up of
μ *m*(sinθ*V2/R + cosθ*g)
don't you?
don't you?
LowlyPion, thank you for your quick response, but I'm not sure what you mean.
in the equation you gave me:
where do the Cosθ and Sinθ come from?
Those are the components of the horizontal force (centripetal) and the vertical force (gravity) that balance || along the surface of the incline.
You may be more familiar with seeing it as
V2/R = Sinθ/cosθ *m*g = tanθ *m*g
I apologize for being so inept, but I'm still lost. Can you show/tell me step-by-step how to get to the correct answer?
Well you originally used:
substituting for N:
To determine the angle θ at the optimal speed for the curve, you are only balancing the downward force of gravity along the incline mg*sinθ against the upward force from the centripetal acceleration (m*v2/r)*cosθ. Or ...
mg*sinθ = (m*v2/r)*cosθ
This formula gives you the optimal angle for radius and velocity with no reliance on friction.
Now that you are entertaining higher speeds, you have another component that needs to be considered (it was previously 0 for the optimal angle at 68km/h). And that is the additional term I mentioned earlier derived from the normal components of gravity and centripetal acceleration and expressed through the coefficient of friction necessary to resist slipping at the higher speed.
LowlyPion said:
Well you originally used:To determine the angle θ at the optimal speed for the curve, you are only balancing the downward force of gravity along the incline mg*sinθ against the upward force from the centripetal acceleration (m*v2/r)*cosθ. Or ...
Okay so I understand that the equation
indicates the force acting down the slope is equivalent to the force acting up the slope (hence, no acceleration up or down the slope and therefore no friction needed).
Furthermore, if I understand you correctly,
[tex]f_s[/tex] = μ *m*(sinθ*V2/R + cosθ*g)
where f_s is force of static friction. Is that right?
Yes. That's correct.
So what they want is what minimum value of μ to keep it from slipping at the increased speed.
I understand that, but I don't know how to do the set up an equation to solve. Could you draw a free body diagram of the car with the added force of static friction? I just can't visualize the forces...
wingman358 said:
Okay I managed to figure it out with the help of this website: http://www.batesville.k12.in.us/physics/PhyNet/Mechanics/Circular Motion/banked_with_friction.htm
(Those are better drawings than you could have expected from me I can say.)
You have figured then that the frictional force must account for the excess the centripetal force from the speed and can be added to the gravitational component of force down the incline. Knowing the other values then you can solve for μ.
  • · Replies 97 ·
  • · Replies 24 ·
  • · Replies 42 ·
  • · Replies 20 ·
