Continuous Charge Distribution?
The discussion centers on the concept of continuous charge distribution, specifically regarding charged metal balls and their charge uniformity. It is established that while a charged metal ball appears to have a uniform charge distribution, this uniformity is disrupted at the atomic level due to the discrete nature of protons and electrons. The atomic arrangement leads to a non-uniform distribution of charge, which can be ignored in most practical applications because the spacing between atomic charges is negligible for macroscopic observations.
  • Understanding of electrostatics and charge distribution
  • Familiarity with atomic structure, specifically protons and electrons
  • Basic knowledge of macroscopic vs. microscopic observations in physics
  • Concept of continuous vs. discrete charge distributions
  • Research the principles of electrostatics in detail
  • Explore atomic structure and charge interactions at the quantum level
  • Study the implications of charge distribution in conductive materials
  • Learn about the mathematical modeling of charge distributions
Physics students, educators, and professionals interested in electrostatics, atomic theory, and charge distribution analysis will benefit from this discussion.
wajed
http://www.vias.org/physics/bk4_06_07.html
This is a quote from the mentioned website,
" For example, a charged metal ball will have charge spread nearly uniformly all over its surface, and in for most purposes it will make sense to ignore the fact that this uniformity is broken at the atomic level"
May I know how is that uniformity broken at the atomic level?
Also, may I know,exactly, when/how does it make sense to ignore that fact for most cases?
the charge distribution is caused by the net charge, either positive or negative, comprised of either protons or electrons.
The reason the net charge is not uniform at the atomic level is because the net charge is made up of a bunch of smaller charges (either protons or electrons) bunched up close together. If you viewed the surface at the atomic level, it would look like a bunch of small pieces really close together, eg:
and not like:
___________________________
if it were the latter, then uniformity would not be broken at the atomic level, however we know that the latter is not possible as everything is comprised of atoms.
Honestly it seems stupid that the site even mentioned that, unless it goes into atomic analysis of the charged structure...ive never even seen that mentioned anywhere, as the spacing between atomic charges is negligible for almost all purposes.
  • · Replies 18 ·
