Plot the graph of the electrical field
The discussion focuses on plotting the electric field created by a point charge of 10^-6 C as a function of distance, specifically from 0.1m to 1m. The correct equation to use is E = k*q/r², where k = 9 x 10^9 N·m²/C², instead of E = Q/(4πe)d². The participants confirm that the graph should reflect an inverse square relationship, and the y-axis must accommodate a scale that spans a factor of 100 due to the range of input values.
  • Understanding of electric fields and point charges
  • Familiarity with the equation E = k*q/r²
  • Basic graphing skills in physics
  • Knowledge of inverse square laws in physics
  • Learn how to plot electric fields using Python libraries such as Matplotlib
  • Research the concept of electric field strength and its applications
  • Explore the implications of inverse square laws in different physical contexts
  • Study the significance of constants like k and ε₀ in electrostatics
Students in physics, electrical engineers, and anyone interested in understanding and visualizing electric fields created by point charges.
jayjay112
Graph Help!
Plot the graph of the electrical field created by a point charge of 10^-6 C as a funtion of distance to the charge. Plot the graph for the range of the distances from 0.1m to 1m
Should I use this equation... E= Q/(4.pi.e)x(d^2) as this is for
electric field strength and not eletric field created as asked?
If i do use thsi equation,
Do I need a value for e or can i ignore the 4.pi.e and just use E= Q/(d^2)
Do I graph the value of E to the correseponding value i used for d?
Should the graph be an inverse square graph??
Thanks for your help.
You can use E = k*q/r2 where k = 1/4πεo
That's k= 9*109
Since your scale is a concern as it spans a range of input that is a factor of 10, then your y-axis needs to span a factor of 100.
  • · Replies 16 ·
