The period of trigonometric functions
The discussion revolves around calculating the periods of trigonometric functions, including the effects of transformations and combinations of these functions. Participants explore both the basic periodicity of individual trigonometric functions and the complexities introduced when combining them.
  • One participant requests a method to calculate the period of all trigonometric functions.
  • Another participant states that the period of a transformed trigonometric function can be expressed as T/b, where T is the original period and b is a scaling factor.
  • It is noted that the periods of tan and cot are π, while sin, cos, sec, and csc have a period of 2π, with a geometric rationale provided for this distinction.
  • A participant seeks clarification on the transformation of functions and confirms that the period of f(ax+b) is T/a.
  • Concerns are raised about the periodicity of sums of trigonometric functions, with an example provided to illustrate that such combinations may not be periodic if the individual periods are incommensurate.
  • Another participant elaborates on the conditions under which the sum of two trigonometric functions can be periodic, emphasizing the need for commensurate periods.
Participants generally agree on the basic periods of individual trigonometric functions and the effects of transformations. However, there is disagreement regarding the periodicity of sums of trigonometric functions, with some arguing that they are not periodic unless certain conditions are met.
The discussion includes assumptions about the definitions of periodicity and the conditions under which functions can be considered periodic. The exploration of incommensurate periods introduces complexity that remains unresolved.
ShayanJ
Insights Author
Hi everyone
Could you give me a way to calculate the period of every trigonometric functions?
thanks
Mathematics news on Phys.org
Let [tex]\text{trig}\, x[/tex] be any trig function and T be it's period. The period of
[tex]a\text{trig}\, b(x+c) + d[/tex]
is T/b.
The period of tan and cot is [tex]\pi[/tex] and the period of the other functions (cos, sin, sec, csc) is [tex]2\pi[/tex]. This can be remembered by the geometric definitions (sin is opp/hyp, cos is adj/hyp etc) by noticing that the ratio opp/hyp etc doesn't repeat until a complete revolution, but the ratio opp/adj and adj/opp does because (-opp)/(-adj) = opp/adj.
Just to be clear, I think qntty was saying that if f(x) is a function with period T, then the period of f(ax+b) equals T/a. Is this correct?
Yes your right.
and what about functions that are the sum of two or more trig functions and the ones that have trig functions as their nominator and/or denominator?
Generally, if you have two trig functions added together, the function is no longer periodic. Take for instance:
f(x) = sin(sqrt(2)PI*x) + cos(PI*x)
then
f'(x) = sqrt(2)PI*cos(sqrt(2)PI*x) - sin(PI*x)
Periodicity implies that f(x) = f(x+T) and f'(x) = f'(x+T). However, think about it... since the two periods are incommensurate, there is no T which you can multiply by two different integers to give you multiples of the periods of each individual sin/cos. To do this would be to solve the equation
t1 = 2PI/sqrt(2)PI = 2/sqrt(2) = sqrt(2)
t2 = 2PI/PI=2
T = n*t1 = m*t2
Such as to find the smallest possible pair of numbers (n, m). But since t1 and t2 are incommensurate, and since n, m are integers, this equation has no solutions.
In fact, functions such as sin(ax) + cos(bx) will have solutions iff the periods are commensurate, that is, they satisfy the equation I gave, and then to find the period, you find a T using the same equation.
  • · Replies 28 ·
  • · Replies 20 ·
