| New Reply |
Is stainless steel magnetic? |
Share Thread | Thread Tools |
| Apr7-09, 09:09 AM | #1 |
| Apr7-09, 09:50 AM | #2 |
some stainless steels are magnetic. so some seaching for the types/classifications of stainless steels.
| Apr7-09, 09:54 AM | #3 |
Recognitions:
Generally the higher the nickel content the less magnetic.
All stainless steels will effect a compass but austenitic (300 series) won't stick to a magnet. |
| Apr7-09, 09:55 AM | #4 |
| Apr7-09, 10:13 AM | #5 |
The 400 series stainless steel (martinsetic, e.g., 440C stainless) is generally magnetic, while the 300 series (austinetic, e.g., 304 and 316) is not.
| Apr7-09, 10:27 AM | #6 |
i think i jumped the gun with my answer. considering this is a physics forum i think my reply should have been something like this:
yes, all materials are "magnetic", they all have atoms which have electric and magnetic fields as properties. the question is too general. if you (the OP) is asking if you can have a magnet stick to stainless then for some stainless steels you need a very strong magnet while for other types of stainless a weak magnet will stick to it. |
| Apr8-09, 02:29 AM | #7 |
Iron has two crystal structures, ferrite which is magnetic and austenite which is not (it is paramagnetic, not ferromagnetic). So if your steel contains enough ferrite, it will be (ferro-)magnetic, if not, it won't. Note that martensite is "metastable" austenite, but with a deformation of the crystal structure, and apparently, it is also ferromagnetic.
| Apr8-09, 03:51 AM | #8 |
ok so i see there is no cut an dry answer to my question . |
| Apr8-09, 03:56 AM | #9 |
| Apr8-09, 06:29 AM | #10 |
what do you mean by ferro magnetic
| Apr8-09, 06:43 AM | #11 |
if i remember right from high school physics, Ferro Magnetic means that it is easily magnetized. the domains in the metal align according to the magnet therefore becomming magnetic *i think*.
Google? |
| Apr8-09, 07:31 AM | #12 |
| Apr8-09, 07:36 AM | #13 |
does ferro mean conating iron , ya pretty much i mean will a magnet stick to it
my chem teacher told me that iron ,cobalt, nickel and liquid oxygen would be affected by a magnet. |
| Apr8-09, 02:11 PM | #14 |
all matter is subject to interaction with magnetic fields. the amount of interaction depends on type of material and flux of magnetic field. |
| Apr8-09, 02:36 PM | #15 |
is the magnetic field bending the light or the gavitational field made by the magnetic field bending the light.
| Apr8-09, 02:41 PM | #16 |
In classical electromagnetism, no. In QED, there are extremely small corrections which would make for photon-photon interactions, but they will not be such that light is bent, but rather scattered. Extremely strong magnetic fields will however generate, in general relativity, some curvature (generate some gravity) and that may bend light theoretically. But we are talking about extremely tiny effects here, which, I would guess, are not open to experimental inquiry, as they are so terribly small. |
| Apr8-09, 02:42 PM | #17 |
Recognitions:
A magnetic field doesn't create a gravitational field - other than the mass of the magnet of course! |
| New Reply |
| Thread Tools | |
Similar Threads for: Is stainless steel magnetic?
| Iron/Stainless Steel | Chemistry | 8 | ||
| Thickness of T304 stainless steel | Mechanical Engineering | 5 | ||
| Which stainless steel? | Materials & Chemical Engineering | 3 | ||
| Stainless Steel | Chemistry | 10 | ||
| Stainless Steel and Magnetism | General Physics | 2 | ||
