Geometric Progression: Calculating the nth Partial Sum
  • Thread starter Thread starter latentcorpse
    Geometric
The discussion revolves around calculating the nth partial sum of the series 1 - x + x^2 - x^3 + ... Participants are exploring the properties of geometric series and the implications of their formulas in this context.
  • Mixed
  • Some participants attempt to apply the formula for the nth partial sum of a geometric series but express confusion over the results they obtain. Others question the validity of their substitutions and the implications of dropping terms in the summation.
Participants are actively engaging with the problem, raising questions about their calculations and the behavior of the series. There is a suggestion to adjust the summation index to include the first term, which may clarify the confusion regarding the results.
Some participants are also discussing the divergence of the series \sum \frac{1}{n+1} and its comparison to \sum \frac{1}{n}, indicating a broader exploration of series convergence and divergence principles.
latentcorpse
what is the nth partial sum of
[itex]1-x+x^2-x^3+..[/itex]
i don't understand why i can't do this?
i have [itex]\sum_{k=1}^{n} ar^k=\frac{a(r^{n+1}-r)}{r-1}[/itex]
ok but then when i sub in i get messed up i get [itex]\frac{(-x)^{n+1}+x}{-(1+x)}[/itex] is there any way of simplifying this? also when i set n=1 i get that the sum is -x when it should be 1-x?
Do you know how to derive the nth partial sum of 1 + x + x^2 + ... ?
off the top of my head isn't it something like
[itex](1-x)(1+x+x^2+...+x^n)=1-x^{n+1} \Rightarrow 1+x+x^2+...+x^n=\frac{1-x^{n+1}}{1-x}[/itex]
also, another thing I'm having trouble seeing is why [itex]\sum \frac{1}{n+1}[/itex] diverges.
my initial instinct was to use the copmarison test with [itex]\sum \frac{1}{n}[/itex] as this diverges.
so if i can show [itex]\frac{1}{1+n} \geq \frac{1}{n}[/itex] then all is well but in fact [itex]\frac{1}{n} \geq \frac{1}{1+n}[/itex] e.g. set n=1 to see
what's going on here?
How can you modify this so that it works for [itex]1 - x + x^2 - \cdots[/itex]
There's no need for the Comparison Test. Just note that
[tex]\sum_{n=1}^\infty \frac{1}{n + 1} = \frac{1}{2} + \frac{1}{3} + \cdots = \sum_{n=2}^\infty \frac{1}{n}[/tex]
would it have a numerator of [itex]1-(-1)^nx^{n+1}[/itex]?
I don't know this of the top of my head, but if you write up what you did to get that, I can look it over.
WHAT would? You started talking about
[tex]\sum_{i= 0}^n (-x)^i[/itex] <br /> and then changed to <br /> [tex]\sum_{n=0}^\infty \frac{1}{n+1}[/tex]<br /> <br /> Are you back to the first question again?[/tex]
Looking at your equation right here, I notice one problem that would fix it rather quickly. When you tried to find the nth partial sum, you are took:
[itex]\sum_{k=1}^{n} (-x)^k[/itex]
The only problem with this is that when n = 1, you get -x just like you got. You accidentally dropped the first term when you switched to sum notation. Just change it to:
[itex]\sum_{k=0}^{n} (-x)^k[/itex]
This way, 1 is the first term. Your new equation is:
[itex]\sum_{k=0}^{n} a*r^k = \frac{a(r^{n + 1} - 1)}{r - 1}[/itex]
  • · Replies 16 ·
  • · Replies 29 ·
