Help with upgrading notebook hard drive.
  • Thread starter Thread starter yungman
    Drive Hard
The discussion revolves around the replacement of a notebook hard drive, specifically addressing compatibility issues between ATA and SATA drives, as well as the implications of different drive speeds and interfaces.
  • One participant inquires whether a SATA drive can be used in place of an ATA drive, assuming the connector compatibility and size requirements are met.
  • Another participant asserts that ATA and SATA use completely different connectors, suggesting that a SATA drive would not work in a laptop designed for ATA drives.
  • A third participant clarifies that a SATA drive can only be used if the motherboard has a SATA connection port, otherwise an ATA drive is necessary.
  • One participant recommends sticking with the PATA drive for the machine, arguing that the cost of a conversion kit would outweigh any potential benefits, especially given the machine's age.
Participants express differing views on the compatibility of SATA and ATA drives, with no consensus reached on whether a SATA drive can be used in the discussed notebook.
There are unresolved assumptions regarding the specific model of the notebook and its motherboard capabilities, which may affect the compatibility of the drives.
yungman
I need to replace my hard drive. The recommendation is: ATA/100 5400 RPM 9.5mm.
I see a lot of faster drive 7200rpm but they are SATA. Is it true I can put this in also because they connector should be compatable. I just need to get 9.5mm or smaller and it would be fine?
What is the different between ATA, SATA etc? Is it true that 100 is 100meg bits per second. So if I get 300, it is ok also.
Computer science news on Phys.org
I'm fairly sure that's not true. ATA and SATA, at least in PC's, use different connectors completely and one wouldn't ever be able to work with another. I don't see why it would be any different with laptops unfortunately.
ATA-100 uses a 100megaBYTE/second interface while SATA uses 300/600/1200 or something of that nature.
http://en.wikipedia.org/wiki/Advanced_Technology_Attachment might be of more help.
Stick with the PATA drive for that machine. You will spend more money trying to find a conversion kit to change the drive connectors (if one is even available) than it is worth. The machine is older so it is doubtfull you will see much of a difference anyway.
Thanks for the help.
  • · Replies 30 ·
  • · Replies 16 ·
