Capacitance of Concentric Shells (different charges)
The discussion centers on calculating the capacitance of two concentric conducting shells with differing charges, specifically a thin shell of radius a with charge q and another shell of radius b with charge Q. The charge distribution is analyzed, revealing that the inner shell has no charge on its inside surface and a charge of +q on its outside surface. The outer shell is theorized to have a charge of -q on its inside surface and a total charge of q + Q on its outside surface. The capacitance is determined using the formula C = Q/V, where V is derived from the electric field E = (1/4πε₀)(q/r²) integrated from a to b.
  • Understanding of electrostatics and charge distribution
  • Familiarity with capacitance formulas, specifically C = Q/V
  • Knowledge of electric fields and potential difference calculations
  • Basic concepts of spherical conductors and their properties
  • Study the derivation of capacitance for spherical shells
  • Learn about the implications of charge polarity on capacitance
  • Explore the concept of electric fields in spherical coordinates
  • Investigate the effects of connecting charged conductors on potential
Students and professionals in physics, electrical engineering, and anyone studying electrostatics and capacitance in conductive materials.
Hemmer
A thin conducting shell of radius a has charge q. Concentric to this is another shell of radius b (b > a) with a different charge Q. How is the charge distributed and what is the capacitance of the two shells. No hint to the relative polarity of the charges is given.
[tex]C = \frac{Q}{V}[/tex]
The difficulty lies in the difference in the charges (I'm sure I'm missing something). Any reference to capacitance I see requires equal and opposite charges, leading me to think the the distribution must be something like:
Inside surface of small shell: no charge
Outside surface of small shell: +q
Inside surface of larger shell: -q (?)
Outside surface of larger shell: q + Q (?)
If I assume that it the charges are -q on inner and +q on outer then I think you could find it by:
[tex]E = \frac{1}{4\pi\epsilon_0}\frac{q}{r^2}\hat{r}[/tex]
[tex]V = -\frac{q}{4\pi\epsilon_0} \int_a^b \frac{1}{r^2} = \frac{q}{4\pi\epsilon_0} \left(\frac{1}{a} - \frac{1}{b}\right)[/tex]
The just find the capacitance simply by [tex]C = \frac{q}{V}[/tex]
But there is no mention of Q which seems wrong. Any help or suggestions very much appreciated.
When you connect the charged concentric shells, both must have the same potential.
The common potential is given by ( total charge/total capacity)
The capacitance of the spherical shell is proportional to its radius.
  • · Replies 23 ·
