Sketch Region of Integration, Reverse Order, Confirm Equality
  • Thread starter Thread starter kieranl
The problem involves sketching a region of integration and writing an equivalent integral with the order of integration reversed. The context is within the subject area of double integrals in calculus.
  • Exploratory, Assumption checking
  • The original poster attempts to reverse the order of integration but questions the correctness of their new limits and calculations. Some participants inquire about the sketch of the region and how the limits should be adjusted accordingly.
The discussion is ongoing, with participants exploring the correct limits for the reversed integral and questioning the original poster's understanding of the region of integration. There is no explicit consensus yet, but guidance is being offered regarding the limits and the sketch.
The original poster expresses confusion over their calculations and the equality of the integrals, indicating potential misunderstandings in the setup or execution of the problem.
kieranl
sketch the region of integration and write an equivalent integral with order of integration reversed. Then evaluate both integrals to confirm their equality
[tex]\int\int[/tex]dydx for 0<=x<=1 and 0<=y<=[tex]\sqrt{x}[/tex]
i rearanged the limits so the equation becomes
[tex]\int\int[/tex]dxdy for 0<=x<=y2 and 0<=y<=1
but my calculations for the first equation came to 2/3 and the second equation came to 1/3
plus the answer is 1/6 so I am obviously doing something wrong. can someone help? have i even written the second equation right?
Did you first sketch the region of integration? The limits for the second integral(with order of integration reversed) should be taken such that you still integrate over the same region. Do you know how to do this?
yeh I am pretty sure i drew it properly??
Since your attachment is pending approval, assuming your diagram is correct, think about the new set of limits you have to use when you change the order of integration. How do x and y vary now?
  • · Replies 19 ·
  • · Replies 105 ·
13K
  • · Replies 17 ·
  • · Replies 27 ·
