How Do You Calculate Power Loss in High-Voltage Transmission Lines?
The discussion revolves around calculating power loss in high-voltage transmission lines, specifically focusing on a line with a given resistance and current. The original poster presents a problem involving resistance, current, and voltage, seeking to determine both the power loss and its fraction of the transmitted power.
  • Participants discuss different equations for calculating power loss, with some attempting to derive resistance from distance and others questioning the correctness of the equations used. There is also an exploration of how to calculate the fraction of power loss relative to the total transmitted power.
Several participants are actively engaging with the problem, attempting various calculations and expressing confusion over the results. Some guidance has been offered regarding the equations, but there is no clear consensus on the correct approach or final answer.
Participants are working under the constraints of homework rules, which may limit the information they can share or the methods they can use. There is an ongoing discussion about the accuracy of the equations and assumptions involved in the calculations.
mlsohani
A high-voltage transmission line with a resistance of 0.345 ohms /km carries a current of 1.05 kA. The line is at a potential of 600 kV at the power station and carries the current to a city located 173 km from the power station.
A>What is the power loss due to resistance in the line?
B>What fraction of the transmitted power does this loss represent?
P=IV
p=V^2(R)
part A>I used the kilometers to figure out the resistance from the distance. I then tried pluging in the values into the equations but the answer is not working.
partB> In order to calculate the fraction I want to make sure I am setting hte first part of the equation correctly. But I assume that you subtract the power loss from the original power.
your second equation is wrong, its P=(V^2)/R
maybe that might help?
also could you tell me the answer to see if i got it right =]
cheers
OK I keep getting it wrong
so I now tried: P=I^2*R
I did 0.345ohms/km * 173 km= 59.685
Then I did P=I^2*R to get> (1.05kA*1.05kA)*(59.685ohms)= 65.8 kW
BUT it keeps telling me I am WRONG! PLease help!
P = I² *R = (1.05kA*1.05kA)*(59.685ohms)= 65.8 kW
You might want to plug that into your calculator again :P
(1,05 * 10³)² * 0.345 * 173 = 65.8 MWIs that the correct answer? (sounds like a little too much to me but I don't know...)
  • · Replies 20 ·
12K
  • · Replies 18 ·
