Gravity, from a different point of view
  • Context: Graduate
  • Thread starter Thread starter Owen
    Gravity Point
The discussion revolves around alternative perspectives on gravity, questioning the traditional view of it as an attractive force between masses. Participants explore various hypotheses, including the idea that gravity may result from a disturbance in a constant force rather than a direct attraction, and consider the implications of particle distribution and vacuum fluctuations.
  • One participant suggests that gravity might be caused by a mass obstructing a constant force from all directions, leading to a net force toward the mass.
  • Another participant refers to the idea as "pushing gravity" and notes that it lacks supporting evidence.
  • A third participant cites Richard Feynman's critique of a similar theory, highlighting that such mechanisms often lead to predictions that do not align with observed phenomena.
  • One participant proposes that if the distribution of particles is Lorentz-invariant, it could explain gravity as a result of matter influencing vacuum fluctuations.
  • A later reply questions how matter influences vacuum fluctuations and whether this influence is inversely proportional to the square of distance.
Participants express differing views on the nature of gravity, with some supporting alternative theories while others challenge their validity. There is no consensus on the proposed ideas or their implications.
Some claims rely on assumptions about particle behavior and distribution, and the discussion includes references to historical critiques of similar theories. The implications of vacuum fluctuations and their relationship to gravity remain unresolved.
Owen
Gravity has always been thought of as an attractive force between two masses. Is there any reason for this view? just because the net result of gravity is that two masses attract each other, is this really all that is going on.
About an hour ago an idea hit me, and thinking about it since then it seems to make more and more sense. could it not be that "gravity" as we see it is caused not by exchange of particles or a disturbance in space time but by a mass getting in the way of another force. There may be a constant force on all objects from all directions, which when out in space and free from any gravitational effects would cancel out. when this force (what ever it may be, a flux of virtual particles in my opinion) passes through a mass of atoms it loses energy. if this disturbed force is now observed out in space away from the mass which it passed through it will be a lower magnitude than the force from all other directions, the net result of this is that any object in this region of space will experience a force toward the mass which disturbed the force.
This may seem a needlessly complicated way to explain a simple effect but I would be interested to hear peoples opinions on it. you never know this might lead to a "better" theory of gravity, more in line with the other 3 forces, but i doubt it.
That's called "pushing gravity" and its not a new idea, but the main problem is there is no evidence for it.
I had a similar idea and posted it once. Got this reply:
ox----------------------------------------------------------------------
Here's what physicist Richard Feynman had to say about
a similar theory:
Many mechanisms for gravitation have been suggested. It is interesting to
consider one of these, which many people have thought of from time to time. At
first, one is quite excited and happy when he "discovers" it, but he soon finds
that it is not correct. It was first discovered about 1750. Suppose there were
many particles [bullets] moving in space at a very high speed in all directions
and being only slightly absorbed in going through matter. When they are
absorbed, they give an impulse to the earth. However, since there are as many
going one way as another, the impulses all balance. But when the sun is nearby,
the particles coming towards the Earth through the sun are partially absorbed,
so fewer of them are coming from the sun than are coming from the other side.
Therefore, the Earth feels a net impulse toward the sun and it does not take one
long to see that it is inversely as the square of the distance... What is wrong
with this machinery? It involves some new consequences which are not true. This
particular idea has the following trouble: the earth, in moving around the sun,
would impinge on more particles which are coming from its forward side than from
the hind side (when you run in the rain, the rain in your face is stronger than
on the back of your head!) Therefore, there would be more impulse given the
earth from the front, and the Earth would feel a resistance to motion and would
be slowing up in its orbit... so this mechanism does not work. No machinery has
ever been invented that "explains" gravity without also predicting some other
phenomenon that does not exist.
What if the distribution of particles is Lorentz-invariant ?
The the argument of more impact at the front of Earth
does not imply. Vacuum fluctuations do have indeed
such a distribution (I remember an old Sci.Am. article
about this.) Gravity would then be caused by matter
influencing the distribution of vacuum fluctuations.
As far as I know, Sakharov had such an idea many years ago.
By the way, check out http://yolanda3.dynalias.org/wbpage/wpage.html !
I don't know much about vacuum fluctuations. How does matter influence them? Is it inversely proportional to square of distance?
  • · Replies 20 ·
  • · Replies 26 ·
