Thread Closed
Electron double slit diffraction with unequal widths
Share Thread Thread Tools
Apr15-09, 04:25 AM   #1
JJ6
Hey guys, I'm working on a problem with a double slit electron diffraction experiment. There is a beam of electrons shooting through two slits onto a screen. When only slit 1 is open, the number of electrons hitting the screen is 25 times the number of electrons hitting the screen when only slit 2 is open. When both screens are open, there is an interference pattern in which destructive interference is not complete. With both slits open, what is the ratio of the probability of an electron arriving at an interference maximum to the probability of an electron arriving at an interference minimum?
2. Relevant equations
Unsure.
3. The attempt at a solution
This is the first double-slit problem that I've seen, so I have absolutely no idea what I need to do to solve this problem.
My instinct would be to just say that since about 25 electrons through slit 1 for every 1 through slit 2, the ratio will just be 26/24 = 13/12, but I'm 99% sure I'm wrong. Assuming this is wrong, why is it?
Could somebody please help me out?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Apr15-09, 06:25 AM   #2
Recognitions:
Homework Helper Homework Help
Number of electrons hitting the screen can be taken a the intensity I of the electron beam. Corresponding amplitude of the De Broglie wave is proportional to sqrt I.
Now find I1/I2. Then find A1/A2.
During interference Amax = A1 + A2 and Amin = A1 - A2.
Hence find Imax/Imin.
Apr15-09, 10:14 AM   #3
JJ6
I1/I2 = 25
A1/A2 = 5
Amax = A1 + A2 = 6, Amin = A1 - A2 = 4
Imax/Imin = (6/4)^2 = 9/4
Is this correct?
Apr15-09, 10:28 AM   #4
Recognitions:
Yes. That is correct.
Thread Closed
Thread Tools
Similar Threads for: Electron double slit diffraction with unequal widths
Thread Forum Replies
KE of Electrons to give same theta as light in double slit diffraction Advanced Physics Homework 4
Deriving the formula for double slit diffraction as in Young from Fraunhofer Introductory Physics Homework 4
Uncertainty in Double-Slit Diffraction Advanced Physics Homework 0
Young's Double Slit vs. Diffraction grating Introductory Physics Homework 1
Double Slit Diffraction Problem Introductory Physics Homework 2
