| Thread Closed |
Hypothesis Testing: Power Function |
Share Thread | Thread Tools |
| Apr15-09, 04:46 AM | #1 |
2. Relevant equations Statistics: power function 3. The attempt at a solution a) Test statistic: Z = (X bar - 13) / (4/sqrt n) Let μ = μ_a > 13 be a particular value in H_a Power(μ_a) = 1- beta(μ_a) = P(reject Ho | H_a is true) = P(reject Ho | μ = μ_a) = P(Z>1.645 | μ = μ_a) = P(X bar > 13 + [(1.645 x 4)/(sqrt n)] | μ = μ_a) I also know that X bar ~ N(μ, 16/n) I am stuck here...How can I proceed from here and express the power in terms of μ and n? Thank you very much! [note: also discussing in other forum] |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Apr15-09, 09:27 AM | #2 |
Replace [tex]\overline{X}[/tex] with [tex]\mu_a+4Z/\sqrt{n}[/tex], rearrange to get [tex]P(Z>\text{whatever})[/tex], then express in terms of [tex]\mu_a[/tex] and [tex]n[/tex] using the normal cdf [tex]\Phi(t)[/tex].
| Apr15-09, 03:03 PM | #3 |
X bar has the distribution N(μ, 16/n). Here, we know the distribution of X bar, so I believe that we can express P(X bar > 13 + [(1.645 x 4)/(sqrt n)] when μ = μ_a) as an integral of the normal density and replace μ by μ_a, but how can I integrate it and get a compact answer? Thank you very much! |
| Apr15-09, 05:22 PM | #4 |
Z is N(0,1), a standard normal r.v.
You can't integrate and get a compact answer. The way to get a compact answer is to express your answer using the cumulative density function [tex]\Phi(t)[/tex] where [tex]\Phi(t)=P(Z\le t)=\frac{1}{\sqrt{2\pi}}\int_{-\infty}^t e^{-x^2/2}\,dx[/tex] |
| Apr16-09, 04:36 AM | #5 |
But in the end, I get a power function in terms of μ_a and n, not μ and n. What should I do? Thanks! |
| Apr16-09, 08:05 AM | #6 |
Good job. |
| Apr16-09, 03:17 PM | #7 |
The quesiton says μ and n, which to me looks like μ can be anything... |
| Apr16-09, 03:25 PM | #8 |
Just replace your μ_a in your power function with simply μ, write [tex]\mu\ge13[/tex] as the restriction and you have the answer.
| Apr16-09, 03:27 PM | #9 |
| Apr16-09, 03:29 PM | #10 |
Put that if you'd rather. Maybe it's better. I'd probably forget even to mention the restriction at all.
| Apr16-09, 03:32 PM | #11 |
Alright!
For part b, Set Power(μ=15)=0.99 The left side should now be a function of n only, and using the standard normal table, we should be able to solve for n, right? |
| Apr16-09, 05:47 PM | #12 |
Right!
| Apr17-09, 02:33 AM | #13 |
Thanks a lot!!
| Thread Closed |
| Thread Tools | |
Similar Threads for: Hypothesis Testing: Power Function
| Hypothesis testing | Set Theory, Logic, Probability, Statistics | 1 | ||
| Hypothesis testing | Engineering, Comp Sci, & Technology Homework | 4 | ||
| Hypothesis testing | Set Theory, Logic, Probability, Statistics | 2 | ||
| Hypothesis testing and the power of the test | Set Theory, Logic, Probability, Statistics | 1 | ||
| Hypothesis testing | Set Theory, Logic, Probability, Statistics | 3 | ||
