What Does the Gravitomagnetic B-Field Describe and What Are Its Units?
  • Context: Graduate
  • Thread starter Thread starter stubbypeeps33
    B-field Units
The gravitomagnetic B-field, derived from the Gravitomagnetic Equations (GEM), effectively represents angular velocity and is associated with frame dragging around rotating bodies. It does not have units of frequency (1/s) but rather describes the rotational effects experienced by test bodies in its vicinity. The discrepancy in conventions regarding the B-field arises from the need for a factor of 2 in its representation, which relates to the spin-2 nature of gravity and the comparison with gravitoelectric charge. For further understanding, refer to the review paper by Mashhoon from 2000.
  • Understanding of Gravitomagnetic Equations (GEM)
  • Familiarity with General Relativity (GR)
  • Knowledge of angular velocity concepts in physics
  • Basic comprehension of tensor calculus in the context of gravitational fields
  • Research the 2000 review paper by Mashhoon on gravitomagnetism
  • Study the concept of frame dragging and its implications in General Relativity
  • Examine the differences between gravitoelectric and gravitomagnetic charges
  • Explore the role of tensors in describing forces between relatively moving objects
Physicists, researchers in gravitational theory, and students studying General Relativity and its applications in modern physics.
stubbypeeps33
Does the gravitomagnetic B-field (from the GEM equations) have units of frequency (1/s)? And if so, what exactly does the B field describe?
I guess what I'm really trying to find out is whether the B field around say a rotating spherical object describes the rate of frame dragging, or does it describe how a particle near it will spin around its own axis, or something entirely different?
And also why is it that because gravity is a spin-2 field, the gravitomagnetic charge is twice that of the gravitoelectric charge?
Thanks,
stubby
Hi stubby,
can you give a reference to put this in context ? I don't know about GEM but in GR the field around a rotating body will induce rotation in test bodies. See Hamilton and Lyle arXiv:gr-qc/0411060v2.
M
Thanks,
stubby
There are various different conventions for the gravitomagnetic B-field, differing by factors of 2. However, they all effectively represent an angular velocity. Basically, if you are in such a field, you feel as if you are rotating, in the same way as if you're in the E-field component, you feel as if you are accelerating. The rotation can be detected for example by rotational frame-dragging of a gyroscope.
The gravitomagnetic equations can't be matched up exactly with the electromagnetic equations; one way or another there's always a factor of 2 needed somewhere, and different sources use different conventions. (Last time I looked, the Wikipedia entry on the subject was not even self-consistent). This does seem to relate to the need to use a tensor rather than a vector as part of the description of the force between relatively moving objects. However, I don't personally know how this relates to "spin 2".
For more details on GEM, I suggest you Google "gravitomagnetism" and have a look at the 2000 review paper by Mashhoon. There seems to be a more recent paper too, but I haven't looked at that.
  • · Replies 44 ·
  • · Replies 16 ·
  • · Replies 0 ·
  • · Replies 18 ·
  • · Replies 72 ·
12K
  • · Replies 42 ·
