How Can We Calculate the Pressure Inside a Sphere With Varying Density Gas?
  • Thread starter Thread starter 78141471
    Pressure Sphere
The discussion focuses on calculating the pressure inside a sphere filled with an ideal gas of varying density, defined by the formula ρ=ρo*(1-r/R), where R is the sphere's radius (5*1010 m) and r is the variable radius. The mass of the gas is given as M=3.3*1050 kg with a molar mass of 2.7 g/mol. The participant derives the force of gravity acting on an infinitesimal layer and formulates the differential pressure equation dp=dF/A, leading to the integral expression for pressure p(r). The method presented is valid and correctly applies principles of physics to solve the problem.
  • Understanding of ideal gas laws, specifically pV=nRT.
  • Knowledge of calculus, particularly integration techniques.
  • Familiarity with gravitational force equations, including dF=GmM/r2.
  • Concept of varying density in a spherical coordinate system.
  • Study the derivation of pressure in non-uniform gravitational fields.
  • Learn about the application of calculus in physics, focusing on integration of variable density functions.
  • Explore the implications of the ideal gas law in different physical scenarios.
  • Investigate advanced topics in fluid mechanics related to pressure distribution in spherical geometries.
Students in physics or engineering disciplines, particularly those studying thermodynamics and fluid mechanics, as well as anyone involved in solving complex pressure-related problems in spherical systems.
78141471
I have a sphere filled with unknown gas. I have to estimate the pressure inside of it.
  • The tricky part is that density of the sphere changes as we go deeper inside of it with the given formula:
    ρ=ρo*(1-r/R), where R is radius of the sphere and is known: R=5*1010m, and r is a variable.
  • Gas has mol mass m=2.7 g/mol.
  • Mass of the whole sphere is M=3.3*1050 kg.
  • Gas is ideal.
  • pV=nRT
  • p=F/A
The force of gravity of an infinitesimal layer of thickness dr inside the sphere at some radius r caused by the inner sphere is:
dF=GmM/r2 where m is the mass of the infinitesimal layer and M is the mass of inner part of the sphere.
Mass m=V*ρ=4*PI*r2o*(1-r/R)*dr
Mass M=4/3*PI*r3o*(1-r/R)
so dF=G*16/3*PI2*r3o2*(1-r/R)2*dr
dp=dF/A
dp=dF/4*PI*r2
dp=4/3*PI*G*ρo2*(1-r/R)2*r*dr
so
p(r)=4/3*PI*G*ρo2*[tex]\int[/tex](1-r/R)2*r*dr from r to R
After making the calculations I will put p(r=0) and get the pressure inside the sphere. Is my method good?
too hard or did I do something wrong?
  • · Replies 17 ·
  • · Replies 16 ·
