Dipole in an Uniform Electric Field:
The discussion focuses on the behavior of a dipole in a uniform electric field, specifically addressing the calculation of torque. The torque is defined as T = p x E, where p is the dipole moment vector and E is the electric field vector. The magnitude of the torque is derived from the equation FLsin(x) = qELsin(x) = pEsin(x), with p defined as p = qL. The conversation also emphasizes the importance of understanding the cross product in the context of torque, particularly when using the right-hand rule for vector direction.
  • Understanding of dipole moment (p = qL)
  • Familiarity with torque and its vector representation
  • Knowledge of the Lorentz force in electric fields
  • Basic grasp of vector cross products
  • Study the right-hand rule for determining torque direction
  • Learn about the Lorentz force and its applications in electric fields
  • Explore vector cross product calculations in physics
  • Review the principles of dipole interactions in electric fields
Students and educators in physics, electrical engineers, and anyone interested in understanding the dynamics of dipoles in electric fields.
fallen186
torque is calculated about the position of either charge has the magnitude FLsin(x) = qELsin(x) = pEsin(x). The direction of the torque vector is into the paper such that it tends to rotate the dipole moment vector p so it aligns with the direction of E. The torque can be expressed most concisely as the cross product: T = p x E
I don't know why the magnitude is F * L sin(x) or why qE turns into pE. And I don't understand what the concept iit s trying to tell me. It would also be helpful if someone could explain the hand thing for torque. I understand most of the stuff about torque but not the hand thing.
x = theta
L = distance between charges in dipole
p = vector of the dipole movement that points from negtive charge to positive.
p =q*L
The dipole moment is defined as being L*q, so qELsin(x) = pEsin(x) by definition. As for F*L*sin(x), that's simply the scalar form of the vector cross product of F x L. Torque is defined as the cross product between the force vector and the vector denoting the lever arm. To find the torque on a dipole, they fix one of the charges as the center of rotation (or choose the midpoint, the result is the same since the magnitude of the force is the same) and assume that the length between the charges (or the dipole moment) to be the lever arm. The force is the Lorentz force resulting from the electric field.
I think you should brush up on torque and vectors because these are very basic concepts.
  • · Replies 21 ·
