How Does Tank Shape Affect Water Stream Pressure and Trajectory?
The discussion focuses on how the shape of a tank affects water stream pressure and trajectory when draining through orifices of different sizes. A cylindrical tank produces lower pressure and velocity compared to a taller, skinnier cylinder, while a conical shape may optimize pressure for longer distances. Key principles include calculating force per unit area and flow rate, as well as understanding Bernoulli's equation for velocity flow. The discussion emphasizes the importance of modeling the trajectory of water, considering factors like pressure head and orifice size for effective design.
  • Understanding of fluid dynamics principles, specifically Bernoulli's equation
  • Knowledge of pressure head and its effect on flow rate
  • Basic skills in mathematical modeling and trajectory calculations
  • Familiarity with orifice flow and its characteristics
  • Research Bernoulli's equation and its applications in fluid dynamics
  • Learn about calculating flow rates through different sized orifices
  • Study the effects of pressure head on fluid velocity and trajectory
  • Explore mathematical modeling techniques for projectile motion in fluids
Students in engineering or physics, educators teaching fluid dynamics, and anyone involved in designing systems that utilize fluid flow and pressure management.
peleus
Hi all,
I'll outline the situation first, then I'll ask about what I need.
Tank (designed by me / other students) which has no closed in top or bottom. Can be any shape, i.e. cylinder / cone / square etc etc. Made from cardboard with plastic bag in the middle acting as waterproof liner.
This sits atop of a reservoir which has a hole in the top of it (bottom of tank) to drain the water. Once in the reservoir it has two bungs in it (parallel to the floor), a 5mm and 10mm. Once these bung's are pulled obviously it drains the tank (downwards) and a stream of water shoots out (sideways), which we have to try and catch in a vessel below and a set distance away. The only variable we control is the size and shape of the tank. It contains 500ml of water.
You tell me :)
First things first, I'm not meant to understand how to do this yet. It's something that will be taught to us over the coming weeks, however I'm trying to do some research into the principles behind it now so I have a better understand anyway.
My understanding of how it works. Assuming a cylinder for a moment, the wider and shorter the tank is, the less pressure per cm^2 we have. As a result we will have a lower pressure stream shooting out of the bung. A taller skinnier cylinder will result in a higher pressure stream (higher force per cm^2). Because this is a cylinder we will have a drop off of pressure over time, from when it is full to where it is empty at a fairly linear rate.
A cone would perhaps be a better shape, we want to keep the water stream resulting on exactly one spot (or as close as possible) which means changing the surface area to less as we have less water to get the same force per cm^2.
Now - I have no idea how to go about modelling the problem. This is what I SUSPECT will be involved.
Working out the force per unit of area, so we can see how much pressure is one the hole in the bottom.
From this we should be able to work out some type of flow rate, so we now what speed the water will be shooting out at.
From there it should be fairly simple math modelling the water as gravity effects it, ignoring air resistance (which may be a big mistake in my design, should it matter indoors?)
I'm not particularly looking for someone to do up an entire spreadsheet modelling the problem for me (of course I wouldn't say no :P ) but really just wondering if someone can point me in the right direction to some good resources to learn those things I suspect are involved, or tell me if any of my assumptions about what is involved is wrong.
Thanks folks.
Force on water is from pressure head (as you described). The thing you describe as 'high pressure' flow is high velocity flow they are not one and the same according to bernoulli's eq.
You want to keep the same velocity flow with a constantly reducing pressure head. You simply can't do that without a variable orifice. So the key is to calculate the best point to switch from the 10mm hole to the 5mm hole.
Now I am not 100% sure on this next point: a cone will put more pressure on the water in the bottom than a cylinder(but I am not sure how much or even how to calculate it). So the best shape of the reservoir will depend on how far you have to shoot the water. If it is further than you can possibly achieve with maximum pressure head with a cylinder then a cone is needed. Youll need to find out an equivilant pressure head.
Modelling the trajectory of water properly is tricky as it doesn't stay together like a solid. You can assume it acts like one though and get a rough arc the water will follow.
To do it you need the flow rate through the orifice, to get a volume of water. Treat this water as a little solid block. Then work out the acceleration and velociites on it until it hits the ground. That should give you a fairly good indication of the arc it wil follow.
  • · Replies 56 ·
  • · Replies 26 ·
  • · Replies 24 ·
  • · Replies 21 ·
