Using the double integral to find the volume bounded betwee two solids
The problem involves finding the volume of a solid bounded above by a sphere defined by the equation x² + y² + z² = 2 and below by a paraboloid given by x² + y² = z. The challenge lies in using a double integral to determine this volume.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the need to express z as a function of x and y, considering the upper hemisphere of the sphere and the paraboloid. There is uncertainty about how to set up the double integral and determine the limits of integration.
Some participants have suggested using polar coordinates due to the symmetry of the equations involved. There is ongoing exploration of how to find the intersection points of the two surfaces, which will influence the limits of integration. Guidance has been offered regarding the integrand and the need to visualize the solid.
Participants are working under the constraint of using a double integral and are trying to clarify the relationship between the two surfaces to establish the correct limits of integration. There is a noted confusion regarding the setup of the integrand and the intersection points.
atarr3
Find the volume of the solid T enclosed above by the sphere x^2+ y^2 + z^2 = 2 and below by the parabloid x^2 + y^2 = z
The double integral. Possiblly polar coordinates (x = r*cos(theta) y = r*sin(theta)). z = f(x,y)
I'm not really sure how to start this one since we have two equations with z. I know we want to find a function to represent z. I was thinking of using the parabloid, so that z = x^2 + y^2 = f(x,y). But I'm not sure of how the sphere comes into play. I also know that the z value is between 0 and root 2 (according to the sphere. And that x and y are bounded by the parabloid. I've tried looking in my calculus for help, but they only use one function with one z in it, not two.
Also, I am supposed to be using a double integral to solve this. Thank you guys in advance for the help!
Your integrand in a double integral is going to be the height (a difference of z-values) between the paraboloid (at the bottom) and the upper hemisphere of the sphere (at the top. To get the z-value for the sphere, solve for z in the equation x^2 + y^2 + z^2 = 2, and keep in mind that you want the upper half of the sphere.
This difference in z-values is going to vary, depending on where x and y are. Hopefully you have drawn a sketch of the two surfaces so you can get an idea of what the solid looks like whose volume you're calculating, as well as where the two surfaces intersect, which will affect your limits of integration.
I would probably do this as a polar integral because of the presence of the x^2 and y^2 terms in both surfaces; that is, because of the symmetry of both surfaces.
I have drawn the sketch already, and I can see I'm dealing with the upper half of the sphere only. Solving for the in the sphere gives z = sqrt(2 - x^2 - y^2), which will be my integrand. I also know that the sphere and the parabloid intersect at the points along the curve sqrt(2 -x^2 - y^2) - x^2 - y^2 = 0. I am still a little confused about how I find the limits of integration
I'm sorry, there's a typo in the one above. The integrand will be sqrt(2 -x^2 - y^2) - x^2 - y^2. I am still unsure of what the limits of integration will be
Whether you do the integration in rectangular coordinates or polar, you're going to have to find where the paraboloid intersects the hemisphere. (It does so in a circle.) Your integration will be much simpler if done using polar coordinates, as the integrand will be sqrt(2 - r^2) - r^2. For limits of integration, theta is easy-- 0 to 2pi. r is a little harder, as it ranges from 0 to whatever its value is at the circle where the two surfaces intersect.
Wouldn't the integrand be r*(sqrt(2-r^2) - r^2) when we go from rectangular to polar coordinates?
As to where the two objects intersect, I know it occurs when x^2 + y^2 = sqrt(2 - x^2 - y^2). I'm not really sure how to solve for that. I know it means that r is equal to the square root of the right side, so the highest value of r is the quartic root of (2 - x^2 - y^2). Putting this into polar coordinates, we get quartic root of (2-r^2).
I'm not sure if that's what I'm supposed to be doing to find the points of intersection.
If I transform to polar coordinates, I get r^2 = sqrt(2 - r^2). Solving for this, I get r = 1, which would make the limits of integration for r is 0 to 1.
  • · Replies 19 ·
  • · Replies 27 ·
