Pulley and block system tension & acceleration
The discussion focuses on a pulley and block system involving a 2kg hanging mass and an 8kg mass on a frictionless surface, connected by a massless string over a frictionless pulley weighing 6kg. The moment of inertia of the pulley is given as 1/2MR^2 with a radius of 0.1m. The participants clarify that the tension in the string is not equal due to the mass of the pulley, and they emphasize deriving equations from basic principles rather than relying on canned formulas to determine tension and acceleration.
  • Understanding of Newton's 2nd Law of Motion
  • Basic principles of mechanics, including tension and acceleration
  • Knowledge of moment of inertia calculations
  • Familiarity with frictionless systems in physics
  • Derive equations for tension and acceleration in pulley systems
  • Study the application of Newton's 2nd Law to multi-body systems
  • Learn about moment of inertia and its impact on rotational motion
  • Explore real-world applications of frictionless pulley systems in engineering
Physics students, mechanical engineers, and anyone interested in understanding dynamics in pulley systems and the application of Newton's laws in real-world scenarios.
heyrefusuck
For the following: 2kg. hanging mass and 8 kg. tabled mass are connected by a massless string passing over a frictionless pulley with a mass of 6kg. The 2kg. mass moves vertically and the 8kg. mass moves on a horizontal frictionless surface. The moment of I of the pulley is 1/2MR^2. The radius of the pulley is 0.1m
Q1. What is the accel. of the 8 kg. mass on the table. My answer was that since the pulley system is frictionless then the tension on both masses will be equal. Therefore there will be no resultant force causing an acceleration on the 8kg. mass on the table. Is that right?
Q2. What is the tension on the string connected to the 2kg. mass. Answer: The formula that I presume I use is T = (2m1m2 /m1 + m2) 9.8
Am I on the right track? What would be the final unit in the amount of tension?
Thanks!
No.
(1) The tension is not the same throughout the string, since the pulley has mass.
(2) Even if the tension was equal on each mass, that would not imply no net force on the 8 kg mass. (What other horizontal forces act on that mass?)
Rather than use some canned formula, derive your own starting with basic principles. Analyze the forces on the two masses and the pulley and apply Newton's 2nd law to each. You'll end up with three equations and three unknowns.
Tension, like any other force, will have units of Newtons.
  • · Replies 27 ·
  • · Replies 17 ·
  • · Replies 22 ·
  • · Replies 29 ·
  • · Replies 52 ·
